G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Engine, Drivetrain & Forced-Induction (https://g35driver.com/forums/engine-drivetrain-forced-induction-19/)
-   -   Dyno'd 6mt sedan with mods (https://g35driver.com/forums/engine-drivetrain-forced-induction/9484-dynod-6mt-sedan-mods.html)
g35_6gear Sep 8, 2003 05:35 PM
Got my 6mt sedan dyno'd today after installing a set of 350Z Mines test pipes. Dynapack dyno
241.1 hp with 210 ft.lbs of torque
Gained 10 ft lbs of torque from 2750 rpm to redline and 5hp
from 2750 rpm's to redline. Definately worth the cash.
Mods
Injen CAI
Coupe center section exhaust
Mines 350Z test pipes
Custom Intake Plenum (similar to Crawford Plenum)
Grounding Kit
DrRick Sep 9, 2003 10:00 AM
Re: Dyno'd 6mt sedan with mods
dont dyno pak dyno's show about a 10 to 15 hp increase? impressive increase, regardless.......
Doc
You have been weighed.....You have been measured.....and you have been found WANTING!!!
Riv Sep 9, 2003 06:02 PM
I'd love to see the chart, any way you could scan/post that?
Thanks.
Riv
DaveO Sep 9, 2003 06:10 PM
g35_6gear,
Impressive Hp numbers. I'm sure you could "worry" most Coupes, 350Zs and many other performance vehicles.
Could your describe your "Custom Intake Plenum". Pictures?
Thanks,
DaveO
g35_6gear Sep 10, 2003 07:13 PM
Unfortunately I don't have a scanner. The plenum is similar to the Crawford plenum but I made some changes to the design because the sedan has about 3" of clearance under the hood instead of the 1.5" the 350z has. The front section is 2 1/4" tall to match the rear section of the plenum. I also made the interior plate bolts longer so they are just below the lid.....this means that if they were ever to back out they could not go more than 1/8" and could not fall into the intake. I deleted the top center drilled hole that the Crawford has as well. Essentially it looks like a Crawford but has my own mods to suit the sedan.
modman Sep 10, 2003 09:39 PM
Are those H.P. figures to the wheels, and if so why the drop of in torque, also does anyone know the drive train loss for the 6 MT.
© 2026 MH Sub I, LLC dba Internet Brands
