HKS Hiper-Ti Best Price Anywhere Guaranteed Free Air filter
No one will beat our prices! We got HKS Hi-Power cheaper than anyone else Guaranteed! Dont wate your time with all the other competitors that claim to have the lowest prices but dont even have them in stock.
HKS Hi-Power Ti Exhaust All Competitors Beat http://www.gruppe-s.com/Ben/engine/3...hiper_350z.jpg Inspired and designed from endurance and GT racing in Japan, HKS developed its Hi-Power Exhaust system for both turbocharged and naturally aspirated applications. HKS has incorporated this new race inspired offset muffler and piping design into many street applications, which offers a greater flow and higher-PRM power gains due to the less restrictive design. Pm for Best Price Anywhere HKS Racing Suction All Competitors Beat http://www.gruppe-s.com/Ben/engine/3...ction_350z.jpg HKS Racing Suction Reloaded Kits have been developed as the leading intake system for high performance applications. Each kit features aluminum suction pipes that have been tested for optimal air flow. Included in each kit is HKS' Reloaded filter with its patented Super-Funnel and new technical advances Pm for Best Price Anywhere GReddy SP2 http://www.gruppe-s.com/350z/zex/grd_sp2.jpg The new SP2 features a 304 stainless steel muffler canister with extra strong 430 SS end caps that feature a deep, high polish. Large, high volume mufflers provide maximum flow with a deep, pleasing tone and are especially effective when used on vehicles with aftermarket turbocharger systems. The unique outer curled oval tip (115 x 110mm dia.) is embossed with the famous GReddy logo. Employing state-of-the-art robotic seam welding, the single wall canisters feature increased rigidity for maximum durability and life. $569 Shipped Free Helix Test Pipes Tanabe Touring Medallion http://www.gruppe-s.com/350z/zex/tan_tm.jpg A refined level of performance and driveability is available in the MEDALION TOURING. The elegant, well defined appearance of MEDALION TOURING is mature, and matches the artistry of a tastefully built, highly tuned machine. [B][COLOR="Red"]$775 Shipped JIC Y Pipe http://www.gruppe-s.com/Ben/engine/3.../jic_ypipe.jpg JIC Downpipes replace restrictive downpipes freeing up hidden horsepower in your turbo engine. Each down pipe features larger piping and smoother piping bends to maximize horsepower and torque gains. All made with high quality stainless steel and given a high polish finish. Spartan Y-pipes for the VQ35DE Nissan Motor has a true 'Y shape' design and adjustable flex pipes for a perfect fit. $475 Shipped Helix V2 SS Test Pipes http://www.gruppe-s.com/350z/zex/z33_testpipe.jpg The Helix Test Pipes are excellent for the performance minded 350z or G35 owner. These testpipes feature 2.25" SS304 fully polished stainless steel construction and includes o2 sensor bungs. Furthermore these new V2 test pipes feature a reinforced support bracket that eliminates exhaust, y-pipe, and header flex under acceleration / deceleration. Without these support brackets Y-pipes, headers, and exhausts are prone to cracking. 03-05 VQ35 $135 Shipped AEM http://www.gruppe-s.com/Ben/engine/3...0z_intakes.jpg Manufactured and assembled in the USA. AEM high flowing filter and cold air extension enables an increase of 7-10HP to the wheels. 50 State Legal and C.A.R.B. approved. Available in: blue, red, and polished CAI 03-05 VQ35 Pm For Price 06-07 VQ35HR (Dual Intake) PM For Price Injen http://www.gruppe-s.com/Ben/engine/3...n_cai_350z.jpg The Injen Technology cold air intake system is a high-performance, dyno-proven system made of CNC mandrel bent 6061 T-6 aluminum alloy. Each Injen cold air intake is carefully engineered for a perfect fit and superior performance. Many other Injen Cold Air Intakes are made of only 3.00" diameter tubes. This may cause friction between the battery and the intake system, dented hoods and an unbalanced air fuel ratio which can be harmful to your engine. CAI 03-05 VQ35 Pm For Price Injen Exhaust http://www.gruppe-s.com/Ben/engine/3...st_ti_tips.jpg G35 cat-back w/ H-pipe and 4 1/2'' straight tips $789 Shipped G35 60mm cat-back w/ H-pipe and 4 1/2'' Titanium tips $875 Shipped Skunk2 Plenum Carbon Composite Spacer http://www.gruppe-s.com/Ben/engine/3...num_spacer.jpg This spacer is dyno proven to outperform aftermarket manifold plenums currently being sold. The skunk2 spacer effectively increases plenum volume, lowers intake air temperatures, and allows front cylinders to breath more efficiently resulting in gains of up to 10+ hp to the wheels, and increased throttle response. 03-05 350Z/ G35 $175 Shipped Brian Crower http://www.gruppe-s.com/Ben/engine/3...ne/bc_vq35.jpg The 3.5L (3498 cc) VQ35DE is used in many modern Nissan vehicles, but the most popular US chassis for engine upgrades are the Nissan 350z and the Infiniti G35. Unlike the inline six cylinders (RB26, 2JZ), the VQ35DE is a V6 configuration. It was on the Ward's 10 Best Engines list for 2002 through 2006, the only engine to be on Ward's list every year since it's inception. Stage 2 Camshafts $899 Shipped Valve Spring/ Retainer Kit $365 Shipped Brian Crower Valve Set - In & Ex $499 Shipped BC Valvetrain Combo Stage 2 Camshafts/ Valve Spring/ Retainer Kit/ Brian Crower Valve Set $1725 Shipped Brian Crower 4.1L Stroker Kit BC 4340 billet steel crank (86.4mm stroke). Avail. balanced or self-balanced. BC 4340 Pro Series steel billet connecting rods w/ARP 220,000 psi fasteners. CP aluminum forged pistons (any bore size, any compression ratio). 9310 nickel carbon steel alloy wrist pins available as a standard feature. Ductile iron plasma top rings, tapered second ring, low tension oil rings. 86.4mm stroke req. block clearancing & removing piston squirters. Plugs incl. Kits are available fully balanced ready to install or unbalanced. ACL Race Bearings sold seperately. $4199 Shipped Berk High Flow Cats http://www.gruppe-s.com/350z/zex/berk_hfc.jpg The Berk High Flow Cat Pipes are 49 state legal, and will still pass strict California SMOG emissions tests. These high flow cats use new metallic spun high converters for smooth uninterrupted exhaust flow and lighter weight. Adds 5-8HP on an otherwise 100% stock 350Z. • Spun high flow catalytic converters. • Secondary Wide band O2 Sensor ports included for left bank and right bank cylinders. Wideband plugs included if ports are not in use. • 100% bolt on. NO cutting, splicing, hacking, etc. • SUS304 Stainless Steel Tubing & Flanges, unlike most other brands that use mild steel flanges. • True 60mm piping (2.36") tubing unlike most other brands that use 57.15mm (2.25”) piping. 03-05 VQ35 $425 Shipped 06-07 VQ35HR $475 Shipped Helix 38mm External Wastegate http://www.gruppe-s.com/Ben/engine/c..._wastegate.jpg Hey Guys I got a sweet deal on a Helix 38mm external wastegate. This was a sample we got from Helix but decided not to carry it. Sold as its. $120 Shipped Looking for a super rare JDM engine component? http://www.gruppe-s.com/Ben/engine/3...z_rare_jdm.jpg PM for Price |
Hey guys one more sweet deal for you guys on the HKS Racing Suction Intake system. Any competitors prices beat! Plus to sweeten the deal I will include a free HKS Replacement Filter for free ($20 Value). Not only will I beat everyones price but Ill thrown in a free gift as well.
HKS Racing Suction Free Replacement Filter Element All Competitors Beat http://www.gruppe-s.com/Ben/engine/3...ction_350z.jpg HKS Racing Suction Reloaded Kits have been developed as the leading intake system for high performance applications. Each kit features aluminum suction pipes that have been tested for optimal air flow. Included in each kit is HKS' Reloaded filter with its patented Super-Funnel and new technical advances [/COLOR][/SIZE][/I] Pm for Best Price Anywhere |
pmed!
Hey guys I have a sweet deal on a Helix 38mm wastergate.
Helix 38mm External Wastegate http://www.gruppe-s.com/Ben/engine/c..._wastegate.jpg Hey Guys I got a sweet deal on a Helix 38mm external wastegate. This was a sample we got from Helix but decided not to carry it. Sold as its. $120 Shipped |
hks exhaust to 92801
Hks ti exhaust for g35 coupe 04 shipped to 90638. Thanks.
hks exhaust shipped to 94530, thanks!
All Pms sent
Thanks Gruppe-S |
can you beat 1287 on the hks shipped
^ it's can you beat 1199 shipped.
Please present me with a Price Quote from an Authorized HKS dealer.
Thanks Ben@ Gruppe-S |
hks for 06 6mt coupe shipped to 19153?
