NEW! ZSpeed Performance 2007-2008 G35X Aluminum Engine Lower Splash Shields!
Now IN STOCK and ready to ship!
2007-UP Infiniti G35X/G37X Lower Engine Splash Shield The ZSpeed Performance Aluminum Engine Splash Shields provide better protection and are much more durable than the stock plastic splash shields. These include our oil change access door for easy oil and filter changes without having to remove the entire shield. This is ESP nice if you do it yourself. 3 bolts and the door comes off with plenty of room to access the filter and drain plug. Limited availability! Get yours while you can! http://www.zspeedperformance.com/07-...D-zsp2008X.htm http://www.zspeedperformance.com/ima...228635863.jpeg |
ABOUT TIME!!!!!!!!! :D
will this fit over after market swaybars without any modification? |
Originally Posted by ChinkyChoy
(Post 6813873)
Bump!
Bump!
