Making a Signature How To
General Guidelines:
1- Using Photoshop or other editing software design your pic in JPG format. Make the pixel size small enough to fit into our standard box. You can figure out some of the sizes by right clicking others signatures and checking the properties. 1a- Try to make the KB size no larger than 60-70KB, since not all our users are on DSL or Cable. At 56kbps it takes forever for them.[img]/w3timages/icons/smile.gif[/img] 2- Take that pic and upload it to your "Rides". 3- From the "Rides" click on the small pic so it opens up the larger version that is viewed. 4- Right click that larger version and left click properties. The size should match what you configured it to be for upload. 5- Also in the properties you need to highlight and copy the http:\\www.g35driver.com\rides.... line. 6- Take this copy and edit your signature to paste it there with [image] at the front and [/image] at the end. 7- One last note if you change your Signature in the future try leaving the old pic in you Rides. Old posts still look for the link. https://g35driver.com/rides/spec/pix...1050858796.jpg |
