Whats the common thought on SFR??
#47
on
I would recommend Forged Performance.
FP: http://www.ForgedPerformance.com
GTM: http://www.GTMotorsports.com
-George
-George
#48
That's an easy question, PF is right around the corner.
SFR stuff is so nice though, that's how you're supposed to do a TT. Just look at the manifolds! There's only one thing that makes the TT kit unappealing. It's the oil return setup, something that can't be avoided, but just makes things a little more complicated.
#49
#50
Here is a handful of the 200+ builds/tunes/cars we have done. All the shops mentioned and great shops. I would take some time, and call them up and see which one offers the services and package you need, and if possible, make a visit to their respective shops before taking your car in.
http://my350z.com/forum/shop-builds/...ore-rehab.html
http://my350z.com/forum/shop-builds/...rformance.html
http://my350z.com/forum/shop-builds/...k-blocker.html
http://my350z.com/forum/shop-builds/...j-vq35-tt.html
http://my350z.com/forum/shop-builds/...hits-road.html
#51
we are currently doing a custom single turbo altima coupe and a twin turbo G37...
here are a few threads we have done as well...
one of if not the Worlds First Twin Turbo Daily Driven VQ35HR
http://www.my350z.com/forum/shop-bui...base-tune.html
our nissan titan powered vortech APR widebody convertible G35...
http://www.my350z.com/forum/shop-bui...oject-g56.html
600whp on pump gas..
http://www.my350z.com/forum/shop-bui...93-octane.html
600whp on pump gas...
511whp stock motor Vortech on one of our Formula D drift cars...
600whp on pump gas, G35
http://www.my350z.com/forum/shop-bui...-pump-g35.html
first one to hit 300whp NA on a dynojet
http://www.my350z.com/forum/na-build...r-project.html
our video playing on Vortechs main page on their website www.vortechsuperchargers.com
http://www.my350z.com/forum/forced-i...s-website.html
600whp pump gas
http://www.my350z.com/forum/forced-i...4whp-g35c.html
625 whp Z
http://www.my350z.com/forum/forced-i...on-625whp.html
worlds fastest 5AT 350z with a stock motor
http://www.my350z.com/forum/forced-i...t-nitrous.html
600whp...
http://www.my350z.com/forum/forced-i...ain-600-a.html
couple of the worlds fastest recorded stock motor Zs
http://www.my350z.com/forum/drag/279...ock-times.html
my Z 10.4 @ 134
http://www.my350z.com/forum/drag/235...ing-th400.html
Custom GTK 850 Turbonetics single turbo 600+ whp
http://www.my350z.com/forum/shop-bui...netics-st.html
another 600+ whp
http://www.my350z.com/forum/shop-bui...-dyno-vid.html
there is really no reason to leave Florida....
600whp pump gas
625 whp Z
600whp...
my Z 10.4 @ 134
another 600+ whp
#55
yeah.. def liked alot of the cars.. sorry if this is off subject but how bad are the stock heads and intake manifold? im really starting to like the cosworth manifold, just wanna make sure its worth it.. also im wanting to have the heads done over with a mild set up.. like port polish and a nice angle put on it.. would that be ok? or a waste?
#56
If you are going to run low boost or are going naturally aspirated, the Motordyne 5/16" plenum spacer seems to be the best bang for the buck on a VQ35DE motor. For the rev-up motor, you probably should consider the Motordyne MREV 2 intake plenum and the 5/16" spacer.
For a moderate to high boost application you may want to consider the Cosworth intake plenum. It is my understanding that it will add 20-40 hp at high boost.
The VQ heads are already very good from the factory. It is debatable whether it is worth doing any porting or polishing, and you will hear different opinions depending on who you talk to. Unfortunately, I was not able to find any dyno comparisons, but there are guys claiming well over 600 hp with stock heads. If you are on a tight budget, you are probably better off putting the money elsewhere.
On my build, I am running a 2.5" APS exhaust system to keep the sound of the exhaust down to a reasonable volume level, although I know I will not get as much boost out of the turbos as I would with a larger exhaust. With that in mind, I am looking to squeek out any additional hp that may be available elsewhere. I therefore had the exhaust ports matched to the exhaust manifolds and I had the intake and exhaust ports polished to remove any casting imperfections (although I have been told they are minimal). That said, I did so knowing the hp gain would not be much and I got a pretty good deal on the head work.
#58
i think that id pretty much like the same work done on my heads.. nothing serious, just enough to make them perform a lil better and smoother..
I have not yet receiived my Cosworth intake plenum, and I have no idea when it will arrive, so I was not able to do so without holding up the build indefinitely. If you plan on using the Cosworth intake plenum, I would strongly recommend that you order it now. Perhaps by the time your ready to do your head work you will have it in hand. In my situation, I'm left with hoping the intake runners closely match the intake ports.
#59
Here is a Cosworth plenum test we did on a smaller TT kit...this one was the PE TT kit. http://my350z.com/forum/shop-builds/...lthys-car.html
#60
I edited my reply above to indicate "moderate to high boost" instead of "high boost" application for the Cosworth Plenum. Now, if mine would only get here...
Sharif, how well do the Cosworth intake runners match to stock intake ports?
