So I'm thinking about picking up another G35 a few questions...
Coming from a 03 G35C .
I'm thinking about picking up a used 03G35C, it a single turbo AT. I never liked MT, so I am completely fine with AT. The price is within my budget. It has a conservative tune. Components are as follows... Turbonetics Sinlgle Turbo Kit HKS FCon IS Engine Management System Blitz SBC Boost Controller AAM Return Fuel System Walbro Fuel Pump Denso 565cc Injectors Kinetix SSV Manifold Samco Hoses GReddy Catch Can Aluminum PS resevoir APS Coolant resevoir 7 PSI wastegate spring It made 334.1 rwhp and 335 ft/lbs . The tranny has no upgrades, the engine has not been built, internally. It has been driven with the setup for about 9k-10k miles. The car currently has about 64-65k. Again the price is right, the only draw back is reliablity. |
so whats your question again?...
Do you know who did the install/tune?
Good set up, Horrible power-- I'd definitely do a compression check on that.. find out who did the tune.
10k boosted miles on a 65k mile car with no built tranny or engine is a lot IMO.. again compression check!!! and if you buy the car upgrade the tranny right away. EDIT: I guess if it's always been runnin that low of hp-- the tranny probably isn't THAT bad-- GL |
lol sorry it would help if I stated that. Basically what should I look out for? |
GTM did the install and tune.
Eh... in my opinion I would never buy a used boosted car.. just don't really know the true condition of the car.. Even with a compression leak down test and other diagnostics it would be just hard for me to buy a used boosted car. My 2 cents
dont buy it..
Only way I'd buy it is if you did a leak down/compression test, had the tranny inspected, the tune looked at by your own choice of tuners, post up pictures and maybe someone can recognize the car. You never can tell, maybe someone has seen it on YouTube doing 160 right after the install during the break in period....
i would pass
I'd pass too imo
I think I am going topass. G37S coupe here I come.. I'm heading to the dealership on tomorrow or thursday. Thanks fellas
| All times are GMT -4. The time now is 03:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
