Forged Performance: rcdash's twin turbo G35
Old Feb 16, 2009 | 11:34 PM
rcdash's Avatar
Originally Posted by Canadian
Nice car man, but this makes me kind of disappointed because I'm hoping to hit at least high 400s on my 530s and you couldn't even get to 500 with the 700s?
Well I got to it on a Dynojet, uncorrected, SAE, and STD are all above 500 whp at 15 psi. In fact, it's above 500 for a good segment of the upper rpm range. Sharif's dyno is just a bear. I also didn't push the tune to the limit for pump gas. We could've gone to 16 or 17 psi but that leaves no room for error or boost fluctuations. W/M injection or race fuel and 21-24 psi will see well into the 500s on Sharif's dyno.
850bb, yes Mike, true, if you want to see mid 500's on Sharif's dyno on pump, in a 5AT.
You have them for sale too? Link? Would I need anything else besides the turbos and the manifolds?
I don't mean to go OT, sorry rc..
If it helps Mike unload those 850's before I get tempted, please go right ahead! LOL.
Old Feb 16, 2009 | 11:36 PM
XKR's Avatar
XKR
Originally Posted by rcdash
Thanks Mike. Forged actually had to modify the STB to get the JWT TT piping to fit without rubbing. I must've had an early version. There is still actually one spot on the charge pipe that I had to pad with rubber to prevent metal-metal contact under load. And FP didn't charge me a dime for the custom work. Sharif said it was part of the standard clearancing for their twin turbo install. So in a way, they've paid for it too.
Great job Raj...car looks great and is fast as hell....still pissed about the short runway J/k
Old Feb 16, 2009 | 11:37 PM
Canadian's Avatar
Canada, eh?
rc.. Question for you...what gauge did you get for tranny temp? I couldn't figure it out from your mod list. I need a tranny temp gauge. Also, what range should your tranny be in? What is too hot?
Old Feb 16, 2009 | 11:43 PM
XKR's Avatar
XKR
I will PM info to you...
rcdash's Avatar
Well I have a full innovate logging set up, so I can take any sensor off the shelf (read cheap), plug it in, put in the calibration curve, and have it show up in my A pillar. Pretty cool, eh? The actual sensor I believe is an ATM-2258. I have the calibration curve if you need it. It should work with most autometer gauges in standalone fashion and is relatively inexpensive ($20 for the sensor from Summit Racing I think).
Old Feb 16, 2009 | 11:46 PM
Canadian's Avatar
Canada, eh?
Well I have a full innovate logging set up, so I can take any sensor off the shelf (read cheap), plug it in, put in the calibration curve, and have it show up in my A pillar. Pretty cool, eh? The actual sensor I believe is an ATM-2258. I have the calibration curve if you need it. It should work with most autometer gauges in standalone fashion and is relatively inexpensive ($20 for the sensor).
I have DEFI Blue Racer gauges, so if I bought a temp gauge with that sensor on it, it would work right? I would just buy an oil temp gauge and that sensor you mentioned?
EDIT: I just googled that part number and at summit it says it works for autometer...hmmm
http://www.vividracing.com/catalog/d...e-p-32403.html
With that gauge would that just straight up work for tranny temp? Nothing else required?
Old Feb 16, 2009 | 11:53 PM
rcdash's Avatar
The sensor itself just changes resistance values with temperature, but the gauge has to be calibrated for the sensor for the readings to be accurate. Any oil temp gauge/sensor will work just as well for tranny fluid.
Old Feb 16, 2009 | 11:54 PM
Canadian's Avatar
Canada, eh?
Cool thanks. Honestly, I have no idea what you mean by it changes the resistance values and how/why the gauge has to be calibrated lol...
Old Feb 16, 2009 | 11:57 PM
twin001's Avatar
Very nice writeup. I hate reading long posts but this one was very informative. Your car is very nice and as Tony said, no shortcuts were taken. Good job on a well thought out plan.
Old Feb 17, 2009 | 12:09 AM
rcdash's Avatar
LOL. The bottom line is that if the gauge and sensor aren't designed for each other, the readings will be off.
Old Feb 17, 2009 | 12:10 AM
Canadian's Avatar
Canada, eh?
Ah I got you now. Well, with that link I posted the sensor comes with it so it should be made for each other ya?? lol.. I think I'll buy that gauge when the time comes. I'm getting a sweet gauge setup done here pretty soon. I"ll post pics
Old Feb 17, 2009 | 12:39 AM
4MeUwill's Avatar
I can understand your comment. I have nothing against Scott and I stated in the post that this was Scott's STB. He helped me get that thing installed - very good customer service. That bar is a great design, bracing the front of the car across two planes. Kudos to Scott on that. I have a review posted on this site with a very positive review - check it out.
I don't want to start any drama. The bar had a VRT sticker on there and I wanted it off. I asked Scott for a Relentless Autosport decal to cover the "VRT" left behind. It never came and over a year passed. When I was building the motor, I asked Sharif to please put their logo on it and if that didn't cover the VRT, get it re-powdercoated or painted. ForgedPerformance has done a ton of custom work in that engine bay. They deserve that spot. This is their build. Hope you can understand. Peace.
Thanks for your explanation and understanding my comment. It makes a tad more sence now knowing that the bar was one of the older ones that had a vrt sticker on it. I'm shocked that Scott did not send you out a RA sticker for it.
Anyways, you have a very complete car there, probably one of the most compatent 5AT's around.
Old Feb 17, 2009 | 12:54 AM
4MeUwill's Avatar
Question; has anyone ever figured how much more whp is lost through the 5AT's over the 6MT's yet? Might be interesting to know.
Old Feb 17, 2009 | 08:58 AM
rcdash's Avatar
Originally Posted by 4MeUwill
Thanks, and sorry rcdash for me going off topic (xkr is just annoying to me)
XKR is a friend. It's funny, I think my first post with XKR on this site was in a somewhat heated "discussion" over this very same brace. But trust me I know him much better now. Not only is he very knowledgeable with a great deal of experience racing, but he's an all around great guy - and I'm sure you are as well. Let's just bury the hatchet?
In regards to the question, typical builds on Sharif's dyno that are 6MT but otherwise identical net almost exactly 500 whp. I'm at 475. So that's looks like an additional 5% drivetrain loss. I make up for it with my rear differential final gear ratio. It's 6% higher than stock. Few folks realize that gearing has no effect on dyno results as dynos take it into consideration (by monitoring speed over time), but it makes a big difference on the road.
Old Feb 17, 2009 | 01:41 PM
  #30
XKR's Avatar
XKR
Here is the way I look at it....not only am I an on line friend of Raj...I am also a personnel friend that knows him in person....If I don't have the right to tell him he should add more Forged Performance stickers...where the hell do you get the right from to tell him where he should or should not put a sticker
Sorry RAJ....I tried to hold back...Sorry !!
