Vortech 2.87 can't be tightened
Old Aug 13, 2020 | 04:14 PM
nyucca's Avatar
6MT/boosted
Is there a reason vortech is retarded and the pulley slides all the way on until it seizes to the jackshaft housing? It's brand new.
Old Aug 14, 2020 | 01:29 AM
nyucca's Avatar
6MT/boosted
Problem solved. I let it grind itself clear. Tards don't even test their own products, I guess.
Old Mar 5, 2021 | 01:46 PM
Bassamore's Avatar
You let it grind itself? The 2.87 isn't actually designed for that motor. If you use it you have to grind it down. I had the same issue.
How much boost are you running?
Old Sep 4, 2024 | 05:00 AM
nyucca's Avatar
6MT/boosted
It was 12 psi till stock ECU decide to jack timing up another 3 degrees to 23 LOLOLOLOLOL
OCG35
Oct 22, 2010 10:05 PM
G35pm
Forced Induction
Aug 10, 2004 02:44 PM
