Stillen Stage 4 no power gain
As I drove my back back from OC to Bay Area, I didn't feel much power as it would therefore I took it back to the same dyno shop that I did with my stage2. After 4 pulls...the avarage I got is 286 whp/281 tq. My A/F were 11~10 @6000K rpm. Mine stage 2 was at 283 whp/279 tq. The weather for both time are same (~65F)... Any recommendation ? thanks
Will try to post the dyno result as soon as I can get the scanner to work |
you sure everything was installed correctly?
uhm... something is wrong. dunno what. /me subscribing
Where did you get the stage 4 parts installed at? Do you have a boost gauge?
take it to Stillen, they're in Cali. They will tell you what's wrong.
dam, that kinda weak. that only 25hp more than i have n/a. somethings gotta be wrong. best of luck
what are you using for tuning? there maybe something is wrong with the install and i would also assume you are running pretty rich. Lower power is better then higher boost + running lean and this thread titled "CRAP stage 4 stillen blew my motor" But good luck nate, and hurry so you can spank that vette! =)
I would have to let stillen look into tuning since it's their locked piggyback box |
