The Official "What gas are you using and how much" thread
You're supposed to use premium.
Our compression ratio is 10.6:1, which is pretty high and the vehicle will run better on 91-93 octane fuel. Anything more than that is just overkill and won't do anything since all you need is enough octane to prevent detonation without the car having to back off the timing a few degrees to do so.
No, Premium (91,93) is simply the highest octane you can buy at the usual corner gas pump. VQ35's are mapped for 91 octane. Anything lower can cause your engine to knock and perform worse. No, premium wont last longer. You are not necessarily hurting your engine unless you do hear knocking, and lots of knocking can lead to detonation, AKA, your motor will blow like Paris Hilton in her night vision sex tape
You scared me with that analogy.
I gotta say the gas prices are killing us. In philly it is about 3.40 a gallon and a full tank runs about $56 dollars or so. I hate to break the bad news, but just today BP announced that it had to shut down part of the alaska pipe line which supplies the US with about 12% of its full. The paper said that fuel prices are going to rise at least another 10-12 cents per gallon if not more
Think if it this way. You may have to pay a few more dollars extra per fillup by using 91 octane, but that's like giving up a coke or coffee every so often. But, not only that, by using 91 octane, it will keep the car running better so that in the long run, you won't have to worry about other mechanical problems.
Preventative maintenance starts as soon as you get your car.
I tend to never fill up so the car is lighter (lighter = fast acceleration) i always put in a half tank of shell v-power. I like both shell and chevron both are the same to me i just prefer the shell name. usually put in 9 gallons and cost me 30 dollars. The only time i fill up is when i am going to orlando from sarasota...
