do 05' g35's have tire issues?
Do the 05' g35's have feathering issues like the the 04's and 03's?
ha????
But I love cornering. |
??????? feathering is a major problem for the 350z...not the g35
^^^ i have feathering on my '05 :o
Originally Posted by M6_G
+1 both my front tires are feathered out as well... summer tires have seen max 15K on the road.
Our G's have negative nonadjustable camber built in. Just a fact of life on sport pckg suspensions. Don't know about non sport pckg.
Toe can cause this too, being toed out. My toe was off from the factory when I had the alignment checked at 6600 miles new. Aftermarket camber kit is the only way to correct the camber and bring you to 0 degrees and get more life from your tires. A drop will increase negative camber even more. I'm assuming you're referring to the inside tread wear/feathering. |
| All times are GMT -4. The time now is 11:02 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
