G35 & G37, Coupes & Sedans
How to correctly drive an MT.
Rating: Thread Rating: 3 votes, 5.00 average.
  #646
Old 08-10-2018, 12:13 PM
cleric670's Avatar
BANNED!!!
Received 2,456 Likes on 2,150 Posts
Coupe 6MT Premium RAS
All depends on how much fuel you want to spend. 60mph is somewhere around 2k in 6th.
  #647
Old 08-10-2018, 10:19 PM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
We speak in MPH here.
  #648
Old 08-11-2018, 09:02 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Originally Posted by 05Gee
60mph in 6th gear 🤔? That's more like 4th for me 80-100 5th above sixth that's just how I drive maybe I drive wrong
I don't know if I'd call it wrong but you're definitely burning through a lot more gas than you should be and putting added stress on the motor and transmission.
  #649
Old 08-11-2018, 09:08 AM
cswlightning's Avatar
There's absolutely no reason to drive like that and it's causing excess wear and poor efficiency from your motor - it's definitely wrong!
  #650
Old 08-11-2018, 09:59 AM
herrschaft's Avatar
I don't know whats wrong with all of you, but I like cruising on the highway at 6K+ RPM. It clearly helps break down the carbon buildup inside the engine...
cleric670 (08-11-2018)
  #651
Old 08-11-2018, 01:11 PM
cleric670's Avatar
BANNED!!!
Oil is carbon based, cruising at 6k does help accelerate the breakdown of oil so technically YES it does help break down the carbon inside the engine lol.
  #652
Old 08-14-2018, 09:39 AM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
6th is like an over drive. My car does the same top end in 5th as in 6th. #governed
  #653
Old 08-16-2018, 11:45 PM
05Gee's Avatar
unsure if your being sarcastic, however I normally shift around 4k sometime around 5k if I want more toque. My mph may have been inaccurate because around 100mph on freeway I was at 5200rpm and I dont normally drive it that aggressive but I can definately pull if you do drive this way.
  #654
Old 08-16-2018, 11:48 PM
05Gee's Avatar
appreciate the response , so when are you typically shifting at what rpm? I live in the bay area so 5th and 6th gear are pointless unless the roads are empty at night. So maybe that's why I probably go high rpms in 4th.
  #655
Old 08-16-2018, 11:51 PM
05Gee's Avatar
thanks is for the tip I'll treat my vq better. Normally I'm shifting around 3k - 4k normally aggressively around 5k . Pretty sure some of you on here would say that's normal.
  #656
Old 08-17-2018, 05:36 AM
Blue Dream's Avatar
Our G is an automatic but my GTO is a M6. I shift normally around 4K in daily driving but it's hard to keep my foot out of the LS2. On the highway at 75 MPH in 6th the GTO hums along at about 1700 RPMs. I get better gas mileage on the highway in the Goat than we do in the G but the G has a 3.5 diff with a 5AT.
  #657
Old 08-17-2018, 06:59 PM
herrschaft's Avatar
I was being sarcastic. Yes, the VQ is sluggish until you get over 4K but always driving around in high RPM's is a great way to burn through gas and attract cops.
  #658
Old 08-19-2018, 01:15 PM
Can confirm. I averaged 16 MPG this weekend pretending I had a race car trying to keep up with the bikes.
  #659
Old 08-19-2018, 02:14 PM
That's actually not that bad considering I get like 20 shifting at around 4.5k on my daily drives with a couple redline blasts mixed in. Was this 16 MPG achieved after 1700 miles of WOT relining every gear (track driving) or was it more just normal spirited street driving with the occasional max accel pull to keep up?
  #660
Old 08-19-2018, 02:41 PM
950 miles was to and from the roads getting 25 mpg. The other 800 was twisty roads lol.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: How to correctly drive an MT.
