G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   The G-Spot (https://g35driver.com/forums/g-spot-185/)
-   -   Help! - Can't shut down my car - won't lock - I Key problem (https://g35driver.com/forums/g-spot/260993-help-cant-shut-down-my-car-wont-lock-i-key-problem.html)
xz35 Dec 18, 2008 02:22 PM
Hi guys, I took apart my dash last night in my 05 G35x, and installed a PAC AAI-NIS2 and an Ipod cable - nothing too major, and then put everything back together...
After I put everything back, the car now won't recognize my I-Key. Here is a list of what it's doing
-I can't shut down my car all the way (I can't turn the ignition all the way back to lock position)
-The key light is red (as opposed to green)
-I can still start my car even though the key light is red
-The car is making a constant beeping sound (probably due to the fact that I can't fully turn off my car)
-I can't lock my doors (again, probably because I can't fully turn off my car)
-car not responsive to any Ikey button (lock , unlock , etc)
Anybody have any idea what's causing this? (and how I can fix it)
I am considering taking the car into the dealer and have them look at it, but will my warranty be affected because I put in the PAC AAI-NIS2?
I would appreciate any input...my car is currently making sad beeping noises at me.
Thanks
Row2k Dec 19, 2008 02:31 AM
my best suggestion would be first to check all the fuses, see if you blew any and after that take the dash apart and try retrace your steps / reinstall the ipod interface.
Odds are that your warranty is shot because you attempted this on your own...an infiniti dealer won't let this slide, I would imagine that no dealer would, so honestly I would rip the dashboard back apart or you can try your luck with the dealer, but be ready to grab your ankles.
STCLAIRWEST Dec 19, 2008 04:31 PM
dont take it back to the dealer, adding things to your car especially re wiring things will definitely fuc.k up your warrentee
Darkstar752 Dec 19, 2008 04:46 PM
You definitely want to get an audio tech or elec tech to look at that if you can't figure it out. There's also a way to re-program the key somewhere on these boards, it might be in your manual.
If you go to the dealer, they will void your warranty. Maybe even your drivetrain warranty because it screwed up the ECU.
djamps Dec 20, 2008 02:06 PM
Sounds lke you forgot to plug something back in or in good enough when re-assembling your dash...
Take it back apart and check everything very carefully...
xz35 Dec 22, 2008 03:37 PM
Car's fixed -
So I went back, took everything out, checked all the connections and tried again, and everything seems to be fixed now. From reading the forums, my best guess as to what happened the first time when I did the install was I had somehow messed with one of the I-key antenna. I had crammed the PAC unit all the way in the back to the right, and apparently that is right where an I-key antenna is, so either the PAC unit was interferring with the antena or I had accidentally knocked the anteana loose when cramming the thing back into that space.
Either way, the car is fixed now and running great. Thanks everyone for your input.
Freshmex23 May 1, 2016 04:05 PM
i had the same problem EXACT same symptoms and everything but the solution to my problem was different. when you remove the shift knob there is a short plastic rod that connects to the knob mine was in the wrong position. all i had to do was take the rod out turn it 90 degrees and put it back in. i just bought the car so i assume that it got messed up when the previous owner had an after market head unit installed. keep in mind i have the G35X not sure if this will work on all other models.
© 2026 MH Sub I, LLC dba Internet Brands
