I can't get MP3 CD's to play for the life of me...
I'm using TDK CD's...burning using Nero.
What do you guys use to burn? Are there any settings or something that I'm missing? This is driving me nuts. I'm ready to pull this factory piece of **** Bose HU out and put in an aftermarket one but I just hate the look of aftermarket stereos. |
You must burn as a Data cd, and just dump mp3s on there, maybe you are burning it as an audio cd?
Yea year is your G? Only the 2005+ plays mp3's.
His sig says 06 coupe...........
Ive burned as audio and data they both play for me! what is the bit rate? also make sure they are not mp4 format.
I use TDK and Nero and mine plays just fine. Are you closing the session when you burn? I had issues like this before in a different car and it was because I was leaving the session open when I was burning. Silly mistake, but it happens.
Closed Session data CD with MP3s in Individual folders (18 - 22 songs) at 192 KBPS max. Use a converter to convert all MP3s that are above the 192 KBPS.
So basically you're going to have a CD that has multiple folders that allows the data trees to be utilized. Don't dump all your songs onto one CD. |
my stock stereo (03 C) was playing burnt cds for a little while, then the whole f in thing locked up, wouldnt play the radio or anything. someone told me that the 1st gen, even the 350s that the stereo would take sh** if you put burnt cds in it. well thats what mine did so i went with an aftermarket DD pioneer. problem solved :)
Originally Posted by gzywzy1k
(Post 4245745)
Actually I'm having the same problem as gzywzy1k; i got the CD changer put in my 05 G35C and about 3 weeks after I started playing burnt MP3 CD's the entire stereo wont even emit audio!! :(
Originally Posted by codeflux
(Post 4245833)
bullsh1t. i've been playing burnt CDs in my CD player since i got the car in 2004. i don't own a single factory CD. never had a single problem.
MP3 CD's wont work for me either, i just gave up
it didnt work for me either
but now i use Itunes and they work.... i dont know the problem tried Nero, Roxio, Windows media player, they all didnt work. But I Tunes works. For me anyways. |
You have to burn as data,
Burn the cd as if you were just backing up files Just dump all the folders (albums) into a burn folder (mac) then click burn... |
ill try Itunes today and see if they work
| All times are GMT -4. The time now is 08:56 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
