G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   The G-Spot (https://g35driver.com/forums/g-spot-185/)
-   -   New G35X Owner...can I install a factory Navigation system if I don't have it?? (https://g35driver.com/forums/g-spot/330924-new-g35x-owner-can-i-install-factory-navigation-system-if-i-dont-have.html)
G Girl 928 Mar 26, 2010 04:11 PM
I recently purchased a pre-owned 2007 G35X. This is my first infiniti and I love it. It doesnt have Navigation however, it has the monitor and bluetooth. After researching, it seems like I need a DVD unit installed in my glove box. Is this true? Where can I purchase this and what else do I need? The most important question is, will it work??
4DGS Mar 26, 2010 05:04 PM
If your car has the LCD then it has the DVD installed as well. Look at your glove box, the upper portion will flip *up* and expose a disc drive. The previous owner must have removed the DVD before selling it to you, which is unfortunate as they are kinda expensive.
Welcome to the forum btw, since your female..... hide your legs or prepare for leg humping from our notorious "post n00dz driver members"
Nav isn't all it's cracked up to be, mine is pretty wack.
Blue Dream Mar 26, 2010 05:27 PM
Blain she's got an 07 sedan. They all have the display but not all have nav, hence the DVD.
G Girl check this section and post up in there. You might get a quicker response. https://g35driver.com/forums/g35-sedan-v36-2007-08-217/
4DGS Mar 26, 2010 09:17 PM
Oh wow, didn't even notice that.
Blue Dream Mar 26, 2010 09:20 PM
That's cuz you wus thinking about humpin. Her leg of course ;)
Damn canadian perv.......haha
BuckeyeInMI Mar 27, 2010 01:00 AM
G Girl, welcome to the club. Yes, you can most likely add the OEM Nav to your car, but it's not a simple procedure and it's not all that cheap (from what I've read), and in the end you still have the factory Nav, which isn't as good as a good aftermarket Tom Tom/Magellan/Garmin.
And please post no0dz as soon as you can. I don't like to look at a G35 pic when it's wearing anything, especially those slinky 2nd Gens. :p
Wrathernaut Mar 27, 2010 01:59 AM
Yeah, it'll be damned expensive and require a new wiring harness. Best bet is to just buy a garmin, since as a 2007 sedan, even an aftermarket double din with nav is pretty much out of the question.
There is a garmin external unit that'll connect to the AV inputs in your center console though.
Mustang5L5 Mar 27, 2010 11:53 AM
I agree, it prob would be cheaper and easier to buy a garmin, but a factory navigation setup looks a lot more appealing than a suction cupped $100 garmin.
Of course, i'm not sure the cost of adding an OEM setup in this case would be worth it. I'd imagine it would be several grand and tearing your entire dash out to accomplish this.
Wannabe6MT Mar 27, 2010 12:14 PM
Has anyone even done it to a 2nd gen yet?
Wrathernaut Mar 27, 2010 03:38 PM
I think only one has done it to a 1st gen even.
Here's what you had to swap out in an 05/06. I'd expect you'd have a similar amount of stuff to replace in the 07+
https://g35driver.com/forums/attachm...i-complete.jpg
Mustang5L5 Mar 27, 2010 06:31 PM
Not shown is the DVD-disk reader that fits in the pass side upper glove box. Wow, you'd think someone would rather do a DD NAV setup vs going through the trouble to swap all that? The OEM nav isn't just NAV. It does vehicle maintainence, fuel economy, alerts you to if a door is open and you drive off, and uses vehicle speed to determine position when you are in a tunnel...so there is a lot of stuff to swap and connect to.
The 07+ sedan uses a hard-drive based system, which also stores audio music. So something tells me it would prob be more complex vs a 1st gen NAV system.
jibberjabbers Mar 27, 2010 07:16 PM
looks like ur better off getting a portable unit. If you wanted navi, u should have purchased a car with one in the beginning.
G Girl 928 Mar 30, 2010 04:05 PM
Thank you!
1 Attachment(s)
Wow, I didn't know so much work was going to be involved. I really don't mind not having a NAV system. I was just curious if it can be done in the future. For now, I guess I'll continue using my Magellan GPS.
Thanks for the heads up on the leg humping as well. This is my first Infiniti! Any tips, news, etc. please let me know! I've uploaded a pic of my new (for me) baby...
Thanks Guys!
G Girl 928! ;-)
blazeplacid Mar 31, 2010 08:52 AM
to me those are just little extras and I myself wouldn't use them everyday
buy a decent Nav around $1000 and you will be more than happy.
Buy a $150 scangauge and it will tell you alot more than just fuel economy
OKStateG35 Mar 31, 2010 10:20 AM
I almost considered buying an '06 nav unit off of eBay and installing it. Came with everything in that picture (plus DVD reader) except the full wiring harness. I think it just had the pigtails that plugged into the unit itself. Not sure if you can splice those into a non-nav harness or not. The guy seemed to think you could because he had purchased it to install in his Coupe, but ended up wrecking it. I think it sold for around $300-$400.
Oh well, I probably would have gotten in over my head and then my wife would have made fun of me.
© 2026 MH Sub I, LLC dba Internet Brands
