hfc or test pipes?
Old Feb 16, 2011 | 09:42 AM
maxcoolg35's Avatar
hfc or test pipes?
Ok so I recently bought my xo2/kcr exhaust and I want to know what is the better option hfc or test pipes and would work great with the xo2/kcr. Also as alot of people on the forms im kinda on budget so if any body could help id really appreciate it and videos would also be very helpful if you would like to show me your setups.
Old Feb 16, 2011 | 09:56 AM
sykoenigma's Avatar
depends on where you live..HFC are more likely to pass inspection, test pipes no way
Old Feb 16, 2011 | 12:22 PM
Songle6MT's Avatar
Test pipes will be more raspy. Does your state have inspections? If so do HFC like said above.
Old Feb 16, 2011 | 03:54 PM
maxcoolg35's Avatar
I live in florida and what is a good brand for hfc that wont break and give good hp with kcr?
Old Feb 16, 2011 | 05:00 PM
g35Davo's Avatar
Test pipes will make it raspy
Old Feb 16, 2011 | 06:00 PM
Nice G35!'s Avatar
I have the same question, I wanted to get test pipes on my G35 AT, But the question is they make my Check engine light come on?
Old Feb 16, 2011 | 06:45 PM
sTeadFasT96's Avatar
You guys need to use the search feature. That's how I've found ALL of my info.
I have Megan Resonated Test Pipes on my x02 and in regular cruising it sounds GOOD, but under heavy load at 3,000rpms and up it'll rasp.
My setup has an engine light and my friend with the same setup doesn't. Just luck with the built in sensor extenders.
Old Feb 16, 2011 | 07:08 PM
Xet's Avatar
Xet
Florida? Do they even have any car laws? Go ART pipes, great sound and the best power.
Old Feb 19, 2011 | 01:21 PM
McLaren23's Avatar
Probably, HFC will give you similar gains, no rasp and it wont hurt the environment
Old Feb 19, 2011 | 01:22 PM
McLaren23's Avatar
+1 on the art pipes
Old Feb 19, 2011 | 01:24 PM
McLaren23's Avatar
I like my berks, but kinetix are cheaper and they do pretty much the same job, if you have stock exhaust it will make it sound better too
Old Feb 19, 2011 | 02:02 PM
maxcoolg35's Avatar
Which would have better mpg hfc or testpipes??? and better hp? any videos with setups? at
Old Feb 19, 2011 | 02:20 PM
G35 Dream's Avatar
Dude there is an exhaust thread under v35 tech. Has a whole thread with vids and advice.
Old Feb 19, 2011 | 02:23 PM
G35 Dream's Avatar
https://g35driver.com/forums/intake-...mpilation.html
Old Feb 19, 2011 | 02:56 PM
walshtj's Avatar
ART pipes > HFC > TP in my opinion.
