Mike's Mount or BlendMount..? RADAR MOUNT..??
I drove ttrank's car solo
Received 1,487 Likes
on
on
I just bought a mount from Mike for V1 and a 8in cord from stealthcords, it was just fine. If you order from stealthcord use "Nicoclubsponsor" for the discount code and Dave a few bucks.
I've had my Mike's mount several years. I did have to remove it once, and reinstall. The only negative that I could comment on was that the tightenining screws that hold the radar detector clamp to the Mike's mount can strip relatively easily if you overtighten them. I believe one of the other mounting products might be a metal mounting assembly as opposed to the plastic assembly from Mike's mount. Not sure if the assembly has changed over the years, or if the screw holes now include metal sleeves in the mounting assembly.
