Steering wheel issues!!!
I had to disconnect my horn fuse. my steering wheel has a mind of it's own when I turn a quarter turn right the bluetooth comes on and the horn sounds non stop. any quick/cheap fix theories?!?!?!?
I would take the cover off and inspect for debris/gunk/pepsi inside the switch.
Spiral cable/clock spring. Idk about the bluetooth but I had the same problem with the horn. But both those things are run through the clock spring
I would remove the steering wheel completely and drive like that.
