Those typical problems are annoying..help needed
so my 03 coupe just hit 78k mile....the passenger side door lock stopped working, nissan claimed the actuator was broken, the parts is 240 itself and 300 to install it, i personally think its a big rip off, anyone has experience with this before?
and also... My sway has been making squeeking noises started efw month ago, went to Tire Factory, and they found out its the SWAY Bar Link that went bad, so it needs to be replace, does anyone knows how much would a OEM Sway bar Link gonna cost me? i need all 4 (front and rear) to be replace. thanks.:) |
i think the oem revised end links aren't too pricey.. like 10 a piece? not sure.. the door actuator seems pretty straight forward if it's similar to the window motor.. if it's not located in the door.. idk what to tell you
DIY! Three phillip screws to take off the door panel, couple of rivets, and it just pops off...very easy...
as for parts, sponsors are here for discounts... |
