Brake Problems
Hey guys
ive had my 04 g35c AT for a month now, and when i brake im startin to hear a slight squeal or something whenever i do... Is it juyst the brake dust or is there some sorta problem with the car? the brakes seem to be working fine though, the noise is just worryin me a bit... thanks |
Re: Brake Problems
Is this when you brake at high speed or low speed? Because mine started to squeal a bit at low speed after about 3 weeks, then it went away...strange.
'04.5 TwilightBlue Coupe [AT5]//Willow Leather//Premium Pkg//Perf. Tire & Wheel Pkg//Sunroof//Splash Guards//Sirius Sat Radio |
Re: Brake Problems
its at low speeds, never happens at high speeds. ill press the brake and itll be fine, but from about 5 mph to the point i stop itll make the noise.
Re: Brake Problems
What you just described is EXACTLY due to brake dust (stuck in the calipers). Next time you wash your car, spray some non-acidic wheel cleaner onto the rotors and rinse thoroughly. This will take care of the brake dust.
____________ MrElussive 03 G35C 6MT |
