G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   Options for replacing front intake "coupler" (https://g35driver.com/forums/g35-coupe-v35-2003-07/362654-options-replacing-front-intake-coupler.html)
Tensecondz 01-04-2011 12:58 AM
Hey Guys - Long time lurker - recently bought an 05 5AT - In the process of changing plugs and removing the air filter / intake, I tore the front (nearest the filter) pliable rubber coupler... I don't believe the dealer sells this piece seperately.
What are my options? Anyone used something aftermarket? Heat and age take their toll on the rubber so not sure if I should try to find a used OEM piece unless someone has a low mileage one they wish to part with....
Thanks!
WataG 01-04-2011 02:47 AM
I'd say just go for a used ztube. Those are all one piece and where the g35 has that rubber coupler part, the ztube is all plastic so your problem shouldn't come back.
Tensecondz 01-04-2011 12:14 PM
The Z-tube uses the same rubber coupler in the front near the filter...
g35sweetness 01-04-2011 12:26 PM
WataG 01-04-2011 02:08 PM
Oh sorry, I thought the part with ridges on it was part of the coupler, woops! I'd still say a used G or Z tube would be your best best. Should be able to find just the tube w/ the piece you need for fairly cheap in the marketplace.
VQ Johnny 01-04-2011 05:25 PM
Something like this would work you just need to find one long enough, most couplers are only about 3" and I think the gap is closer to 4-5". I did look at an OEM parts diagram and it looks like you'd have buy the whole g-tube to get that accordion coupler. Maybe try a junk yard those types of couplers are pretty common.
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Project 01-04-2011 05:27 PM
I think i have mine laying around. Ill look if your interested send me a pm.
nghiars 01-04-2011 06:35 PM
you can probably get something from autozone in the intakes section that will work.. they have these ghetto make it yourself intakes and sells it by parts.. im sure you could find that coupler there... its just a basic rubber hose thats pretty wide.
Awakened2001 06-04-2014 03:00 PM
Im having the same issue but my coupler that attaches to my TB is the one that is falling victim from so many removals etc. Im wanting to replace the stock tube with a Z tube but from what i've seen from all the vendors is that they specifically mention the couplers are NOT included. My coupler has begun cracking behind the hose clamp im guessing from me overtightening it. It is 3" inner diameter right?? I was pretty much already planning on just picking up some universal 3" hose and some decent clamps to take care of the problem.
You know i've been strolling through these forums forever and was just too lazy to register, so glad I did. Everyone here is so helpful for us who aren't full blown mechanics. I'd give myself a 5/10 on my mechanical skills and I can usually fix most things in my 03 G35 just by looking through the DIY section. but anyways..
back on topic will that work i mean the coupler is really just an angled 3" hose isnt it?? or is it 3.5"??
LoSt180 06-04-2014 04:24 PM
An OEM ztube will replace everything. The Stillen "ztube" uses the G35 rubber couplers. The oem one is all one piece.
Here's a comparison I found online. The OEM ztube has both "couplers" built in.
http://cdn.carthrottle.com/wp-conten...0/DSC06974.JPG
rsingerG35 06-04-2014 07:37 PM
I would go the Z tube route.
Gman56 06-04-2014 07:55 PM
I used oem z-tube cost more but its oem. They cant say it voids my warranty ! It is oem
ceizner 10-26-2014 05:49 PM
NISSAN OEM Air Intake-Duct 165775Y700
NISSAN OEM Air Intake-Duct 165775Y700 fits like a glove
https://fusionstorm.box.com/s/olrcf4rt3c6bcl2qgu1c
https://fusionstorm.box.com/s/z80kmafgoio3kilvvmvw
