G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   ??? Think it's the wheel bearing (https://g35driver.com/forums/g35-coupe-v35-2003-07/389947-think-its-wheel-bearing.html)
TruGame Sep 29, 2011 04:01 PM
So today my G35 stopped on me , I had the wheel bearing & hub replaced last month and today I was 2 blocks from my house and boom something by the drivers side rear tire was making a loud noise like something came loose and was grinding???
http://i82.photobucket.com/albums/j2...4/dc35043b.jpg
BW350GTskyline Sep 29, 2011 08:40 PM
I think the 04 coupe are either 2 piece hub and bearing assembly or if i remeber correctly its one whole piece
Project Sep 29, 2011 08:46 PM
fronts are one piece rears have to be pressed....did you take a look behind the wheel or just call the tow?
TruGame Sep 29, 2011 08:50 PM
yes i looked behind the wheel and nothing but you can hear a loud noise when i put it in gear, it was like something came loose and was grinding
Project Sep 29, 2011 09:00 PM
if yours is stick you sure your throwout bearing or pivot ball didnt shear?
TruGame Sep 29, 2011 09:21 PM
its a stick and it so how much is that
Project Sep 29, 2011 09:44 PM
not expensive if you didnt mess up the clutch or flywheel...i think the pivot balls are prone to shearing and it would explain the grinding you heard. I know my throwout bearing has a lil whine to it sometimes but it goes away. Just giving you a heads up in case you cant find anything else wrong with it.
TruGame Sep 30, 2011 11:02 PM
Go so the guy call me and said I will need a new axel and bearing
Project Sep 30, 2011 11:05 PM
dont forget the alignment lol
© 2026 MH Sub I, LLC dba Internet Brands
