question bout 06 headlights n parking lights
Since the parking light is in the fog light housing when the lights are on is that area lit? Cus I don't ever see that area being lit on cars with the projectors. Are people not installing the bulb in there?
It's only a small 168/194 bulb. As such, it is difficult to see when the projectors are on. It is easily visible when only the parking lights are on.
Damn Cus I jus ordered the kp foglight module for my 03 headlights but then a really good deal came up for the projector lights so I bought them and now not sure if I even need to install the module. I was gonna do yellow fogs but I had previously installed yellow parking lights lol. Hmm Wat to do now. Cus if the parking lights are gonna give me that independent fog light look I was going for then maybe I don't need to bother with the kp . But then Idk if I want the yellow parking lights on the whole time the low beams are on.
Stick with the '06/'07 bi-xenon projectors. Light output is much better. The KP Technologies fog light module allows for independent control of the fog lamps. So, if desired, you could run with just the fog lamps on (and control the fogs using the OEM dash switch). Some people, including myself, run a yellow H1 bulb in the fog location (I also use a yellow 168/194 bulb in the city light location) because they don't like the non-matching shades of the HID projectors and fog lamps.
I jus might not install the parking light then because I don't like the look of both housing sections being on at the same time.
Originally Posted by saywat?
(Post 6470692)
