G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   My dashboard lights won't come on...... (https://g35driver.com/forums/g35-coupe-v35-2003-07/411999-my-dashboard-lights-wont-come.html)
cdta1610 Jul 25, 2012 12:50 AM
when I have the headlights on (night driving). I have had to drive w/no dashboard lights quite a few times. The dash lights come on, but just not when I have my headlights on, to make my post clearer. I am takin' the car in for another issue on Thursday, but am hoping I can fix this issue myself if it's a simple fix. Please help. :confused2: Thanks mucho!
BTW - in ref. to a 2006 G35 Coupe
jsmith29 Jul 25, 2012 01:31 AM
Sometimes when I get in or out of my G my knee will brush up against the dash brightness knob. I'd place a bet that yours is all the way down.
gary c Jul 25, 2012 09:20 AM
Originally Posted by jsmith29 (Post 6522813)
Sometimes when I get in or out of my G my knee will brush up against the dash (brightness knob). I'd place a bet that yours is all the way down.
That's....:icon18:....good advice and exactly where I'd check first....Gary
mikecoupe Jul 25, 2012 11:12 AM
agree with the above comments...many times ive gotten out and my knee scrolled the lights off..scroll it back up
lostangels01 Jul 25, 2012 05:50 PM
I also agree with ^^jsmith29. Also check your fuse box by your dead pedal, for any blown fuses.
cdta1610 Jul 25, 2012 10:12 PM
I have not located a dash brightness knob anywhere...that is one of the first things I checked for. The brightness of the dash is fine in daylight. What baffles me is why the dash won't light up when my headlights are on....I will def. check for a fuse box tomorrow. Thanks.
mikecoupe Jul 25, 2012 11:38 PM
its a scrolly thing right next too where you pop your trunk sir
cdta1610 Aug 1, 2012 09:05 PM
Yeah, that's what I thought when the issue originally presented itself, because in my previous car....looked the same. Thanks for confirming where it was. I don't drive that often at nite, so I haven't even doublechecked to make sure that it's not a blown/short fuse either. Thanks again to all respondents :bowdown:
Sincerely, a ma'am :BOOBIES: :icon17:
gary c Aug 1, 2012 09:36 PM
Let us know if locating the roller switch fixed the dashboard light issue you were having....Gary
Freewheeler Aug 13, 2013 10:25 AM
Hi Guys, I exactly have the same problem in my 04 G35 coupe.Can anyone tell me where can I find the adjustment knob in the 04 version?
dave Aug 17, 2013 07:13 PM
It's by your left knee. By the switch that opens the trunk. It is a little wheel that rolls up and down.
ShoeDriver Dec 31, 2013 07:23 PM
Thanks
Thank you so much! I just got a 04 G35 Coupe & had no clue what was happening, but I got it now! Power of the internet I tell you! :driving:
CEdwards Jan 19, 2014 11:51 AM
alright im having the same problem but accompanying this problem is no running rear lights. brakes lights work when pedal is pressed but when released they go dark. i have checked the fuses. now here lies the main problem: the fuse was blow, alright. so changed the fuse and as soon as i turned the lights on it blew the fuse. well i put a larger fuse in and it did the same thing. so im thinking that it may be the actually headlight switch is done for and may need a replacement. anybody's thought on what could be going on?
infinitidude Jan 20, 2014 08:41 AM
You have a wire touching metal somewhere that is causing a dead short everytime you turn the lights on after fuse replacement. Check front side markers for any fraying of wires because that is where the most common area is. If not there then check harnesses for both tail lamp assemblies. Hope this helps
CEdwards Jan 20, 2014 11:00 AM
i figured it might be the problem but the other problems dont really add up to the wire shorting such as the dashlights dont turn on anymore. also this happened at the same time, dashlights stopped working and i noticed the rear lights out, and also my side markers never have work as long as i have owned her (1 and a half years)
© 2026 MH Sub I, LLC dba Internet Brands
