Check engine light p1078
Hi guys and gals. I need help with my cel. Went to advance auto got the cel of p1078. Got the part installed. Did the cel reset. Also the throttle procedure and still have a cel. My idle has been 1000-1200 rpms. Been trying to fix it for 2 weeks now and don't want to take it to stealership to check the cel for 150. Is there a easy way to do this. Thanks
From my 2006 FSM:
DTC P1078 (Bank 1) P1084 (Bank 2) EVT CONTROL POSITION SENSOR Exhaust valve timing control position sensor detects the concave groove of the exhaust camshaft rear end. This sensor signal is used for sensing a position of the exhaust camshaft. This sensor uses a Hall IC. Based on the position of the exhaust camshaft, ECM controls exhaust valve timing control magnet retarder to optimize the shut/ open timing of exhaust valve for the driving condition. DTC No. P1078 (Bank 1) Trouble diagnosis name: Exhaust valve timing control position sensor circuit DTC detecting condition: An excessively high or low voltage from the sensor is sent to ECM. Possible cause: - Harness or connectors (Exhaust valve timing control position sensor circuit is open or shorted) - Exhaust valve timing control position sensor - Crankshaft position sensor (POS) - Camshaft position sensor (PHASE) - Accumulation of debris to the signal pick-up portion of the camshaft |
P1078 Error Code Stays Alive Regardless - Help Please!
Originally Posted by tommynsxs2k
(Post 6555545)
I went through the procedures of Throttle Valve Closed Learning, Accelerator Pedal Position Learning, Idle Air Volume Learning, Exhaust Valve Timing Control Learning, and Idle Speed Learning, but the Service Engine Soon light comes on, and the high idle problem remains. I'm at my wit's end with Old Reliable (2006 G35 6MT, well-cared for, 124K miles), and would welcome any enlightenment and/or advice on how to remedy the above. Thanks in advance! |
Hi how are you. You have to do the throttle learn precisely.
Tommy:
Thanks for the reply. Are talking about the 1. Throttle Valve Closed Position, or 2. Accelerator Pedal Position, or both? 1., is straightforward, just turn ignition key on, and off, according to the Factory Service Manual. 2., is a little more complicated. I did it several times per the Manual, and felt I was pretty precise with steps and their timing. Maybe I need to revisit it again. |
Ok. I have googled, checked all over this site and went to the Nissan dealership. I have the p1078 code right now. High idle and it runs rough. I replaced the passenger side angled sensor back in Nov. for a cel. Can't remember the code. But back then it was idling fine. It just felt like it would hit fuel cutoff around 4000 rpms or so. It fixed the problem. The question is which sensor needs to be replaced for that particular code. I have seen some say the angled one and some say the straight one. The nissan dealer said the straight one. Which I am taking it is the intake one since it is on the intake side. Lol. But the code is for the exhaust side. Before I spend $100+ on a sensor it would be great to have a positive answer. Thanks.
Originally Posted by Almightyone
(Post 6943912)
Ok. So you are saying I need to order the straight sensor. That is what the guy at Nissan told me. Thanks.
The angled sensor on the passenger side ended up getting rid of my cel. P1078. Just wanted to let people know just in case they run into the same issue. :biggthumpup:
Ok guys there are only 2 part numbers for these 4 sensors, 23731-6J90B is the straight sensor for both sides and 23731-AL61A is the angled sensor for both sides. The angles sensors are the same on both banks as well as the straight sensors.
This is a ****ing trip. Every search I've done has shown that the straight sensor is the cause to the P1078 but now I'm reading it's the angled one? It would definitely explain why My Service Engine Soon light came back on. Just to make sure, it's on the back side of the engine, passenger side correct? That's where the straight sensor was.
Originally Posted by Heytheremr2
(Post 6947355)
Originally Posted by infinitidude
(Post 6947450)
Correct, the straight sensor is directly behind the intake cam and the angled sensor is directly behind the exhaust cam. The angled sensor is the problem sensor. Both on the passenger side. On the driver side it is completely opposite, the angled sensor is for the intake cam and the straight one is for the exhaust cam. Hope this helps brother. |
Awesome bro, glad I could help get this worked out for you.
