G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   Power seat won't move back and forth? (https://g35driver.com/forums/g35-coupe-v35-2003-07/424490-power-seat-wont-move-back-forth.html)
Kicknshift Mar 15, 2013 07:22 PM
So today I went to see a G off craigslist and all went well except a few minor issues.
The issue that was the Worst was the drivers power seat won't move back and forth, and also the oher direction which I'm not familiar with. It will move the seat up and down but nothing other than that. I was curious if this is a simple fix or could be an expensive fix And if anybody has hhad this issue and resolved it?
tszyuenc Mar 15, 2013 07:24 PM
if its the switch problem, check this website out
http://my350z.com/forum/body-interio...placement.html
tszyuenc Mar 15, 2013 07:26 PM
or if its the gear , check this out
http://www.odometergears.com/documen...eplacement.pdf
my pass. seat was out last week and it turn out to be the switch's problem, so i just replace the switch and good to go
partyman66 Mar 15, 2013 09:42 PM
Did it make the electric motor noise but just not move? Or did it do nothing at all when you pushed the switch?
If it made the noise, it's probably the teeth on those crappy little plastic gears. It's an easy but surprisingly expensive fix. I believe the replacement parts are like $65.
dukehotty Mar 15, 2013 09:49 PM
Even if you can do it yourself, putting in new gears could be a realy PITA. If it isn't the gears, it can be very expensive to buy new seat parts from Infiniti. Keep in mind these seats have a bunch of gears/movement plus heaters and air bags. If you are in love with the car, you can always find used seats here at the marketplace or just put in some racing seats.
Kicknshift Mar 16, 2013 12:41 AM
It is silent. Doesn't make any noise. So I guess this problem is bound to cost me.
My only option is to tell the seller that he has to get it fixed or take off a couple hundred off the price.
Also: forgot to mention that the guy is 6 ft 1 and I am 5"10 and its stuck in his position so to press the clutch I have to sloutch in my seat with my head against the back part of the seat and it is really a dumb idea if I buy it as it is. Hah
dukehotty Mar 16, 2013 01:38 AM
I would see if he will fix it first. A couple hundred isn't going to cover your time/money.
350GT_ Mar 16, 2013 02:52 AM
I hear you can manually move it if you open the seat up. That could be a temporary or even permanent fix. A few weeks ago my passenger seat stopped tilting but would slide forward/backward. I remedied that by spraying WD-40 in the switch and letting it sit overnight, which was a solution that I found here on Driver. There was probably gunk in there preventing it from operating properly/at all. Give that a shot -- it may save you A LOT of money for the time being.
Kicknshift Mar 16, 2013 07:02 PM
The owner says he doesnt have time to fix it and is selling as is. He decided he would take off $400 dollars off the selling price. Which seems odd...
So you sprayed WD-40 directly on the switch? like where you push the button? or did you open it up and spray in a specific spot?
350GT_ Mar 16, 2013 07:38 PM
Yup I sprayed it directly onto the switches and around the edges of the switches so that it would go through them and onto whatever is underneath it. It worked really well!
dukehotty Mar 17, 2013 02:12 AM
It isn't odd if he already took it in and got an estimate (expensive) to fix it. He will have a hard time selling it without that seat working.
shawn's g35 Mar 17, 2013 07:02 PM
Rip em' out n put some bride seats in!! :JAMIN:
Mike1650 Mar 17, 2013 08:44 PM
My bet it is the $135 seat switch you can buy from sewellparts. It was on mine anyway. The switch is very poorly designed with small, thin, plastic tangs that move the micro switch. When they break, that's it, no more contact. I have the 2003 (doggy door) model with every rwd option.
kennyk11 Mar 17, 2013 11:19 PM
Mine was doing the same thing, when I checked the fuse box one of the 10 amp fuses was blown... check the fuse box for any blown fuses
Mike1650 Mar 18, 2013 12:03 AM
Pretty sure there isn't a separate fuse just for the up and back. I assumed the other functions were working.
© 2026 MH Sub I, LLC dba Internet Brands
