Originally Posted by jkuo
(Post 6894927)
i think in your situation, you got unlucky and are right between changes in the vb. 04.5 they went to integrated tcm and in '06 they changed one of the solenoids.
Originally Posted by 05G35CP
(Post 6894930)
yep, im very unlucky lol. Luckily i was able to find a 2005 trans that is part # for part # the same.
Also will you do this VB work yourself? or you will ask trans shop to do it for you? |
Originally Posted by g37owner2008
(Post 6894935)
thanks, and wish you good luck for the vb change this weekend, will you keep us updated? I am between changing the whole trans or the vb only. Waiting for your successful story.
Also will you do this vb work yourself? Or you will ask trans shop to do it for you? |
(Post 6894935)
Also will you do this vb work yourself? Or you will ask trans shop to do it for you? swapping the valve body took care of the problem. Car is fixed. Just finished. It took about 2 and a half hrs. It is a very messy job so make sure you have plenty of paper towels. You just have to make sure you remove the correct bolts that hold the valve body in place and once you re-install make sure you line up everything. Take pics. It wasn't to bad at all. Car drives good now. I needed 7 qts to fill trans up. |
(Post 6896120)
and what kind of ATF you r using ? nissan Matic S.? |
(Post 6896181)
good to hear that, good for u, before your swap the vb, will you be able to go to 5th gear? I only have p1757 code, sometimes the car will not go to 5th gear, not all the time.
And what kind of atf you r using ? Nissan matic s.? |
1 Attachment(s)
well i had this problem with my tranny, except my valve body caused me to loose reverse. i ended up getting a used tranny. and i also did the trasgo shift kit. DO IT!!! its the best 200 u can spend. get it from summit its 229 shipped. just replacing the valve body for a new one is 1100 dollars.... so trust me the new tranny even tho it sounds nuts is the cheeper route. our trannys dont go bad very often me and u are just not very lucky. i did alot of research and it dont happen often... and i mean very little lol. so just get another tranny. i recommend www.carpart.com that where i got mine. all there stuff is in good shape when removed. my local guy only uses them for that reason. just my opinion but i feel your pain..... mine just cost me 1500 and that was with me spending 850 on a tranny with 75 k and doing the shift kit and giving my buddie who runs a tranny shop 200 to help me take it in and out. so plan on spending some cash but ull prolly never have to do it again.... this is the pic when i was reinstalling mineAttachment 189815
my bad didnt see u got it fixed :) thank god u didnt have to pull the tranny it wasnt fun at all
Originally Posted by speedcretin
(Post 6897038)
summit racing has the transgo shift kit for 229 def something to look into. i did mine and wow its the best 200 i have ever spent
