Automatic transmission shifting unsmoothly.
I thought maybe I would ask you guys first before I take it for a diagnostic. It's been like this for a couple months now but it never really bothered me until recently.
Some symptoms are: Unsmooth downshifts, say im rolling to a red light and it turns green and I press the gas evenly, the car will jerk forward. Unsmooth up shifts (usually feel it from 2-3 and 3-4 but it isn't a huge problem. Staying in a certain gear when it needs to shift, say I am in 2nd gear and I decide to step on the gas a little harder, it goes to higher RPM's but it takes a while for the computer to decide to shift to a higher gear, even after my foot is off the gas. I really don't know what exactly is going on but some info would be great. |
That is kind of how auto transmissions respond if you don't feather them appropriately. You should not have to press the gas enough to make a rough upshift.
On my old honda it really did not like going from 2>1 when you decided to press the gas upon transition. |
Change oil as recommended by Nissan, same used to happen to mine till I changed the oil now its smooth as butter.
(Post 6924127)
Originally Posted by Usman Ali
(Post 6924164)
If so I'll definitely be on that in the morning. |
Check your fluid level and condition of your fluid. If its brown, or burnt smelling you need to change it right now. Only use OEM fluid.
Also these aren't the most responsive transmissions. So that delay you get when you hit the gas in 2nd sounds normal to me. |
What year G35?
Sedan or Coupe? |
From what you describe your AT is low on fluid since it shifts using line pressure. I recommend taking your G to your favorite mechanic and have him do a "drain & fill" using only Nissan AT fluid! No other AT fluid is recommended, regardless of what a few members think! Don't go to Infiniti unless you have deep pockets, even Nissan is 30% less...Gary
Or change the fluid yourself. If you can change oil, you can do an AT drain/refill on the G.
Originally Posted by rsingerG35
(Post 6924245)
Originally Posted by Kicknshift
(Post 6924180)
Well Ive driven lots of automatic cars and mine is the only one that reacts like this so it's not the way I'm driving. I'm pretty careful on the gas.
Your talking transmission fluid right? If so I'll definitely be on that in the morning. Did you ever resolve the problem? Mine is doing the exact same. I used royal purple tranny fluid when I did a drain and refill. problem started a week after |
Originally Posted by TheefrshstVQ
(Post 7016319)
I found a fix called a grounding kit that somebody sells kits for on this forum. Its suppose to fix this and make shifting much faster. |
(Post 7016346)
I did a tranny oil change and it didn't change. I just got used to it so it's pretty un-noticeable now. I found a fix called a grounding kit that somebody sells kits for on this forum. Its suppose to fix this and make shifting much faster.
(Post 7016319)
NOTHING ELSE ! using the correct specifications J-Matic was superseded by S-Matic So S-Matic would be the correct fluid for G35's |
(Post 7016346)
I found a fix called a grounding kit that somebody sells kits for on this forum. Its suppose to fix this and make shifting much faster. The actual physical shifting aspect of it will remain the same such as the jerking. But I highly recommend this mod as well, it has been known to make a difference despite what some people may say. |
