BCM (Body Control Module) Hyper Flash Modification help needed.
My research so far has shown me Load Resistors are needed to cure Hyper Flashing caused by LED conversion. The G35 does not have a turn signal relay instead it has a BCM that controls the flash rate. Has anyone done a modification to the BCM to control Hyper Flashing instead of Load Resistors at the light connectors? How about installing the Load Resistors near the BCM?
i know you can buy the load resistors and install them in the engine bay because apparently they got hot
