Light Weight Pulleys
Unorthodox Racing Pulleys any thoughts are they worth it, Ill be doing a bigger throttle body soon...
Any Input? Concept Z has them for 330 with belts. |
Well, if your looking to cut out weight off the engine that's a good start. I already have the light weight pulley from stillen and a carbin fiber driveshaft. The car revs up so much faster.
Lightweight pulleys are great. Just don't put one one your crank.
Originally Posted by danoman32
(Post 7041017)
Originally Posted by Siciliang35
(Post 7041020)
Why not on the crank?
Originally Posted by ScraggleRock
(Post 7041055)
Because the pulley is not always just a pulley. It's a harmonic balancer. It's weighted to balance the crankshaft. I had always wondered if our cranks were internally balanced or if that pulley is in fact a balancer.
(Post 7041055)
If you have an automatic, and you want it to be fast, turbocharge it or go home. It'll be slow no matter how much you dump into it without FI!!! |
hopefully ill have the G supercharged, but I'm doing some other things to the car first not sure if I will forge the internals yet or just run low boost with the vortech v3.
Skip the TB, waste of $
Look into the driveshaft as well
or do a FD ring and pinion swap
Do they have underdrive pulleys for the G?
I know that was a big mod for Mustangs. A set of lightweight pulleys, that slow down belt rotation as well. Really freed up enough HP you could actually feel it. Granted, the reduced speed did cause issues like electrical power drain, and cooling issues. But hey, getting stranded on the side of the road at 3AM is well worth 5 HP. :) |
Originally Posted by Mustang5L5
(Post 7041334)
I know that was a big mod for Mustangs. A set of lightweight pulleys, that slow down belt rotation as well. Really freed up enough HP you could actually feel it. Granted, the reduced speed did cause issues like electrical power drain, and cooling issues. But hey, getting stranded on the side of the road at 3AM is well worth 5 HP. :) I did not have any charging system issues, even with a sub and a kicker 500.1 amp. |
Yup they have them. AMS, with brand new OEM belts. Not a bad $100.00 (shipped). I'll keep a close watch on vibes if I install the crank pulley.
https://cimg3.ibsrv.net/gimg/g35driv...6fa96edd4f.jpg |
hey EPiK where u get that set from???
