G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   How many gallons to fill up y'alls gas tank? (https://g35driver.com/forums/g35-coupe-v35-2003-07/455390-how-many-gallons-fill-up-yalls-gas-tank.html)
NyCrAzY May 25, 2016 03:06 AM
Hey guys.
I would like to inquire on how many gallons of gas does your coupes takes to be filled up to a full tank?
The only reason I ask is because my car is throwing a P0462 code (fuel level sensor).
So basically, the fuel gauge would always show more than half full of tank gas when it's really not.
So what I've been doing is filling up my car for every 250 miles I drive (resetting the odometer) after filling up. The other day, I filled up my car @ 250 miles and the gas tank took 15.4 gallons.
What is the most gallons you guys were able to fill up? Thanks.
coffeysm May 25, 2016 11:39 AM
It's 20 gallons total and I get about 17-18 mpg on my 06 coupe. Usually around 250-300 miles I fill up and that's when the light would turn on (usually with about 4 gallons left). I've driven around on E and slightly below it without problems and end up usually filling with about 18 gallons.
You can try cleaning the sensor.
PhoenixG35 May 25, 2016 02:31 PM
Clean sensor or replace. It should fix the problem.
partyman66 May 25, 2016 03:31 PM
There is a DIY instructional on here somewhere that details the process of cleaning the sensor which fixes this for most people. You have to remove the rear seat to get at it.
NyCrAzY May 26, 2016 12:50 AM
Thanks for the advice guys. I will do the q-tip trick.
If that does not work, I have a question.
If I were to purchase a fuel sending unit/sensor ... are the parts for the driver side and passenger side different or are they both the same part? From my understanding, the one on the passenger side is attached to the fuel pump itself? Thanks in advance.
alpa_chino May 29, 2016 10:36 AM
same here...about 18 gallons
Sonford Aug 10, 2016 12:30 PM
I drive city alot so my fuel consumption is pretty shitty. I get about ~160-180 miles on a tank of gas driving city alone. on my trips from Houston to Dallas I get about 280 full tank. Refill hovers around 12-14 gallons
partyman66 Aug 10, 2016 10:47 PM
Even 280 miles isn't that good for a 12-14 gallon fill-up. Do you drive super aggressively all the time, or maybe have really big and heavy wheels/tires? 6MT or auto?
I've had my car since brand new in '04 and the worst fuel economy I've ever gotten out of a full tank was maybe just under 22 MPG. The best I ever got was around 29 MPG on a long road trip by myself of mostly highway driving where I was consciously trying to see what I could get for fuel economy on the second half of the trip, so I went about the speed limit most of the way and tried not to be too crazy aggressive with the acceleration.
Sonford Aug 10, 2016 11:00 PM
I never drive agressive. I recently just purchased this gem a couple months ago. its a 2004 6MT with 57,000 miles. My job is literally down the street and so my commute is NEVER bad. However, driving around the area which is about 5 mile radius always seems to down my tank, and fast too. I don't race or anything like that, just daily driven. Stock 7 spoke wheels with 225 in the front and i think to 285 in the rear? I'd have to check but yeah I thought all G's had the issue of going through fuel super fast. I always pump supreme as well. :dunno::dunno::dunno:
partyman66 Aug 11, 2016 04:37 AM
Stock tires are 225/40/18 up front and 245/45/18 in the rear. You basically have the exact same car as me assuming your mention of 285's in the rear was not true. Mine is also an '04 6MT with about 53K miles on it and stock sized tires.
Short drives aren't the best for fuel economy... more so in cold weather, because the car is the least efficient when it's warming up both in terms of fluid resistance as well as the car running richer until it reaches a certain temperature.
I have a short commute to work as well (6.5 miles each way), but it's not really much stop and go... mostly just go, and about 1/2 of that commute is highway.
What's your usual shifting RPM range in casual driving? Tire pressure set to 35 all around?
Stock exhaust?
Ben_abrams Aug 19, 2016 11:39 PM
costs me like $40 to fill up
But different question, have you guys ever put non premium gas in your cars? Ive never put in anything but 93, would it be a bad idea to put 87 in?
zenkig Aug 26, 2016 06:33 PM
20 gallon tank, holds about 20 gallons.
Usually when I get fuel I'm somewhere around 12-14, I always fill up
NemesisGee Aug 27, 2016 10:26 AM
Profound statement right there.
I do about 10.5L/100km mixed city/highway on an 03 Coupe 6MT with 63,000km on it, summer driven only, bone stock, normal driving not aggressive. Rarely let my cars run low on fuel as some cars use the fuel to cool the pump, so I always fill with just under 1/4 tank. Most I've ever put in was 62 liters and I always stop when the gas pump cuts out. Never top up after the cutoff.
partyman66 Aug 28, 2016 06:47 AM
I wish more people did the same. Manufacturers should put stickers on the inside of the gas tank doors telling people not to top off their tank when filling after it auto shuts off. Most people have no idea that it's bad for the EVAP system... and not just a little bad... pretty much horribly bad and can lead to very expensive replacement of parts designed to last the lifetime of the vehicle in normal use situations.
It always amazes me how sometimes even "car guys" top off beyond the normal fill range. This is one of those hidden gotchas that can kill you when buying a used car from a person who doesn't know cars but otherwise tries to keep up on maintenance.
© 2026 MH Sub I, LLC dba Internet Brands
