2006 infiniti g35 coupe, WON'T START! PLZ HELP
2006 infiniti g35 coupe. Clutch went out, replaced it along with the flywheel wheel and pressure plate, assembled it all back together, bleeded it and got pressure to the clutch but the car wont start. it turns over and cranks but won't start. we dropped the transmission again to see if the flywheel was misaligned but its aligned, and everything is completely hooked up correctly. There is no power to the start signal fuse, at the time of when the clutch went out the codes P1078 and P0335 also went on before we dropped it(car would turn on fine) but now it won't. Replaced the crank shaft pos sensor for the code p0335. please help haha dont know what else to do.
Could be something to do with the clutch switch which stops the car starting if the clutch isn't depressed?
Check your cam sensor, P1078 can also make your car have a really difficult time starting
Hey bud do a quick search... There is a sensor that reads the flywheel rotation.. check the crank sensor..I think that's where your problem is.. Make sure the notches on the flywheel aligned with the crank sensor..
I think to override the cam/crank sensors you can try cranking for 7 seconds. I think**
Originally Posted by BradMD_96
(Post 7079414)
@OP have u tried cranking it for 7+ seconds? |
| All times are GMT -4. The time now is 01:57 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
