Driver's Side Headlight Low-beam not working
Hey guys
So I'm pretty sure the bulb didn't burn out and that it is a connection issue. The driver's side LEDs still work as well as the blinker, and when I signal on that side, the whole unit blinks instead of just the blinker light, and both the tail and headlight on the left blink super fast. I'm thinking it might be a fuse issue? Or is it just a connection issue. I'm not quite sure what to do, and any advice would be greatly appreciated! Also, where are the spare fuses located in a 2003 G35 Coupe? Thank you! |
Update
1 Attachment(s)
https://cimg9.ibsrv.net/gimg/g35driv...2d408f4fb8.jpg
So my friend and I spent a bit fiddling with the lights today, removed the bumper and everything. Did a bunch of troubleshooting with the lights, and eventually we isolated the problem to what we think is the aftermarket ballast and this thing I drew a red circle around. It makes a faint humming noise, which the passenger side headlight doesn't make, which leads me to believe this unit is malfunctioning. Does anyone know what this is called, or have a possible solution? It'd be greatly appreciated, as I don't have the funds right now to by a brand new pair of headlights! |
Originally Posted by phoking_tj
(Post 7082550)
| All times are GMT -4. The time now is 04:27 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
