Brakes
New brakes vs old brakes, yes the old brakes needed to be changed a long time ago. I bought brakes for $80 and they sent the wrong ones even though it was the correct part number, had to pay $27 to ship them back and still haven't got my refund. I figured out they were the wrong ones when I took them to a mechanic to get them installed along with turning my rotors. $150 to turn rotors basically :52: since I didn't get pads installed because they were the wrong ones, they put the old ones back on so I could drive it home. I drove down to a store and got these posi-quiet brakes made by centric and installed them with my dad in 2 hours. That was the first and last time I will ever go to a mechanic, I do everything myself in my garage along with help from my dad but I've been short on time lately. I know it wasn't the mechanics fault for the pads being wrong but they charged me full price still. They scuffed one of my brembo calipers, torqued lug nuts to 115lbs, left rotors dirty. This will definitely be the first and last time going to a mechanic, it's good to know everything was done right when done by yourself. https://cimg0.ibsrv.net/gimg/g35driv...5460486954.jpgThis was before everything was cleaned up, rotor and caliper are extra clean now :)
Congratulations, it's always rewarding when you complete a job yourself! Getting to work with your Dad is just a major plus, I miss those days! I believe the correct torque on those lugs is 80lbs, that's what I've always used.
Gary |
Brakes are one of the easiest jobs to do yourself that mechanics charge way too much for.... especially if they are disk brakes. Most disk brakes literally can be changed in about 10-15 minutes per wheel or less using nothing more than a jack and lug wrench, a C-clamp (often not even necessary), a flat-head screwdriver, some brake-parts cleaner, and a ratchet with just one socket (whatever the size is for the bolt that secures it to the hub).
It's amazing to me how places try to charge $800+ for a simple pad swap while using cheapo generic parts and often not even changing out rotors... that breaks down to like $500 an hour for labor after parts + parts markup. |
1 Attachment(s)
Originally Posted by partyman66
(Post 7114341)
It's amazing to me how places try to charge $800+ for a simple pad swap while using cheapo generic parts and often not even changing out rotors... that breaks down to like $500 an hour for labor after parts + parts markup. I will never use any independent shop no matter how much cheaper they may be. I learned that lesson many years ago Attachment 260124 My vehicle will be 5 years old at the end of this month and I still have the OEM brakes at almost 90k miles. I won't have a problem spending $600 for brakes at the dealer when the time comes knowing the job will be done right with OEM pads Telcoman |
I wanted to go with the OEM pads too but could not find them anywhere online or in store anywhere, I called the local Infiniti dealer and they said they had none in stock so these posi-quiet ones are good for this use. I feel that the initial bite is better than OEM. Only thing is that my brake pedal is a little squishy even though we bled them a lot. Nothing too bad but squishier.
Independent brake/alignment shops, all they do is suspensions!
Originally Posted by telcoman
(Post 7114368)
My local Infiniti dealer charges $279 for the front and $279 for the rear that includes turning the rotors, providing a loaner, washing and vacuuming the vehicle. I will never use any independent shop no matter how much cheaper they may be.
I learned that lesson many years ago Telcoman Gary |
Originally Posted by gary c
(Post 7114392)
With independent brake/alignment shops, if they didn't do great work they wouldn't be in business! Especially if you can find one in your neighborhood others recommend! It's not about the cost or letting the dealership :5091: wash my car (that will never happen) it's about quality work! I know of 4 shops that do high quality work within 30 minutes of my front door I'd trust to work on my coupe, and I've used them all!
Gary Whatever makes you happy. Telcoman |
I have always found a couple trusted shops wherever I live to fix things on my cars that I can't. Even GM dealerships have some trouble with a few things on the GTO's because they are an older model these days. And there is no way in HELL I'd ever let a dealership wash my car. I spend too much time keeping them beautiful for dealership to f*ck it up.
But as said above to each their own. |
(Post 7114368)
I will never use any independent shop no matter how much cheaper they may be. I learned that lesson many years ago :icon43: |
Originally Posted by poolshark
(Post 7114457)
@telcoman: I agree with you. My right rear calipers had rusted and were clamped shut. So rather than driving it to the dealership, I went to a local, independent shop. They ordered new set of rear calipers and pads (I supplied the rotors). When I picked up the car and was pulling out of the parking spot, I noticed that I had to push the brake pedal ALL the way to the FLOOR before it gradually stopped. So, I went back in and told the mechanic and he said to simply pump the brakes. I told him that I did that and it was no better. He said to drive it around slowly and it should resolve but if not, bring it back the next day. Needless to say, I brought it back and they worked on it again; at the end of the second day, he said that it was a bit trickier on these newer cars (really, my 2003 is considered "newer") in bleeding the brake lines. I regret getting the job done by the shop as the pedal feel is not the same as when I had it done over the many years by the dealership.
:icon43: There is an old saying "buy cheap, buy twice" Not only does this hold true for automobile repairs but tools, appliances, TV's and most other items. In my twelve years of being an Infiniti owner I am satisfied with the work that my dealer does. I buy my replacement batteries, tires,air and cabin filters at the dealer and do not care if these items might be a few dollars cheaper elsewhere. Telcoman |
1 Attachment(s)
(Post 7114424)
... And there is no way in HELL I'd ever let a dealership wash my car. I spend too much time keeping them beautiful for dealership to f*ck it up.
. Keep it beautiful for the next owner Attachment 260123 Telcoman |
(Post 7114459)
There are many new inexperienced new owners of older Infiniti vehicles visiting forums such as this one looking for advice. Many are over their heads financially looking for cheap repairs. The problem with using an independent shop is the cheap replacement low quality parts as well as shortcuts they can take to keep their prices below what the dealers charge.
There is an old saying "buy cheap, buy twice" Not only does this hold true for automobile repairs but tools, appliances, TV's and most other items. In my twelve years of being an Infiniti owner I am satisfied with the work that my dealer does. I buy my replacement batteries, tires,air and cabin filters at the dealer and do not care if these items might be a few dollars cheaper elsewhere. Telcoman I guess I took a chance with this shop since it was nearby my home <1 mile away versus the dealership being 15-20 miles away. |
Are you in NJ? Perhaps we are using the same dealer. I'm on my second Infiniti also over 260k miles and will most likely purchase my third Infiniti from the same dealer when the time comes. Telcoman |
(Post 7114488)
