My g35 won’t go over 4K rpm After new muffler installation, what is the issue?
#61
on
P2122
P2128
P2127
P2138
i took the car to Infiniti, apart from rude service they charged 200 for this information and refuse to elaborate on what is the problem. They told me I can leave the car and they’ll find out but I just wanted to get out of that piece of **** place.
P2128
P2127
P2138
Easy to understand after reading this thread.
Telcoman
The following 3 users liked this post by telcoman:
#62
I have no idea how to help the OP, but I believe this could have been solved awhile ago just by simply following directions. Pay to get a proper diagnostic (IDK what Inifiniti did for $200, but that was a waste of time and money) and you can pinpoint your issues.
That service adviser certainly isn't fond of you if that's all you got.
#63
on
The OP obviously pissed off the Infiniti Service advisor?
I have the four volume paper version of the 2006 FSM that I purchased shortly after i purchased my first Infiniti.
There is extensive substantial troubleshooting in the EC (Engine Control) section with all four of those trouble codes. The Accelerator pedal position sensor has two sensors.These sensors send an output voltage to the ECM. The ECM uses these signals for engine performance operation including fuel cut off.
When a malfunction is detected this can put the engine in fail safe mode.
There are two ground connections that need to be closely inspected and cleaned and tightened.There are wiring harness terminals and connections that need to be checked as specified in the FSM page EC 597
The OP is being a complete dick for not obtaining the required FSM and following the logical troubleshooting steps. A consult tool is required for some of this troubleshooting and no dealer works for free especially with someone that calls/refers to the dealer a "stealership" They will usually bill this type of customer more or may not to even want to deal with a customer like him?
Good luck to the OP in getting his POS vehicle properly repaired.
Telcoman
#65
G-Ryder03coupe
Tuner & Dyno
12-22-2014 08:06 AM
V.Capital
09-05-2011 04:50 AM
Juicey G
03-05-2011 11:36 PM
CalsonicVQ
03-14-2007 01:28 PM
