Help
I'm driving down the road and all the sudden my traction control and slip light comes on and will not go off and help
Check your brake fluid. If full get it scanned.
Wheres the cam sensor located? Thank u
Back of the engine behind the cam shafts. If it's not throwing a code then you need to do more troubleshooting. If it does throw a code for the sensor then only replace with a Hitachi or Genuine Nissan part.
(Post 7170033)
(Post 7170048)
The lights is throwing is the traction control and skip and I did research and it says cam sensor also sometimes it will take a few clicks to start
Both have green harnesses attaching them to the main harness; hope you haven't clipped your fingernails in a while, cause they're a pain in the *** to unclip. Aside from that smooth install. However, MAKE SURE you get genuine sensors (i.e. the silver tipped ones). Aftermarket will guaranteed cause the problem again, just a question of a month vs a year. |
Thank u. Do u be chance know the part num all the ones I see online is left and right so I don't know which one it would be
Fixed passenger side cam sensor thank yall
