G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   Car won't start after sitting for a day (https://g35driver.com/forums/g35-coupe-v35-2003-07/468932-car-wont-start-after-sitting-day.html)
MDH713 Apr 26, 2020 03:18 PM
I have a 2004 Infiniti G35 Coupe AT. 3 weeks ago I went out to start my car and it was completely dead. No lights, dash lights, nothing. I was in a hurry to go to work so I grabbed my other car and picked up a battery on my way home. The one in my car was 5 years old. Switched out batteries and it started right up and was fine for a week. This was on a Sunday. Started everyday going to and from work for the week and then sat all day Saturday. Head out Sunday morning to start the car again and its completely dead. Jumped it and it ran fine. Put a load tester on the battery and it read perfect. Went through with my normal work week and everything was fine and then this morning(Sunday) the car is dead after sitting all day yesterday. Battery is brand new and is reading fine. 3 weekends in a row now the car won't start after sitting for a full day. Really don't even have an idea of where to begin with it. Any ideas?
I forgot to add about 2 weeks ago my car was making this real loud screeching/squealing upon a cold start for about 30 secs and then it would go away. It was so loud I was almost embarrassed to start it out in public. It sounded like it was coming from the power steering pump pulley but couldn't be for certain. Took the drive belt off and felt all the pulleys and everything seemed fine. The PS pulley had a little wiggle to it but not much. Not sure if thats how it suppose to be or not. But buttoned everything back up and started the car and the noise was gone and has been ever since. Figure I would add this incase it helps with any info. The car has 190k miles and ive had it for almost 10 years. Not gonna sink a lot of money into it cause ive been looking at a new truck.
cleric670 Apr 26, 2020 04:18 PM
Probably something on that's draining the battery, pull the fuse for the cd disc changer and see if it goes away. The disc changer is a known failure point.
Belt squeal is common, tension the belt as shown in the FSM.
Jeffreybonilla5 Apr 26, 2020 08:23 PM
Sounds like something is draining the battery, sometimes an aftermaket radio/alarm system will drain the battery, sometimes if you installed LED bulbs instead of halogens will do it, ive even heard of leaving the seat warmer button on while the car is off will drain the battery
anynigma Apr 28, 2020 09:41 AM
Check that your battery terminals are nice and tight.
© 2026 MH Sub I, LLC dba Internet Brands
