G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   I've searched and nothing. Will 05-06 G35 19's fit '04 w/ brembos (https://g35driver.com/forums/g35-coupe-v35-2003-07/78194-ive-searched-nothing-will-05-06-g35-19s-fit-04-w-brembos.html)
neo_rambo Dec 13, 2005 04:18 PM
My question is will 19 inch 05-06 g35 coupe wheels fit a 2004 with brembos? The offset for the 19's is 33 rear and 30 front. I know that the 18's are 30 all the way around. But knowing wheels sometimes offsets don't matter as much when it comes to brake clearance. The spoke design is what matters and whether or not it clears. I'm sure someone here with brembos has done this. If so let me know.
Thanks in Advance.
Maximus Dec 13, 2005 04:36 PM
i dont know for sure, but ive seen a few pics of people wit the 05/06 19" on the 03/04's with brembos...hope dis helps
neo_rambo Dec 13, 2005 04:38 PM
can you send me some links I wonder if they use spacers?
Sukairain Dec 13, 2005 05:07 PM
Fits perfectly actually. If you look at the spoke design of the 05+ 19" rims, you'd notice it was designed specificly with the big Brembos in mind. It's a shame Nissan contracted Rays to built such a rim only to take the Brembos out of 6MT models on the G35C the same year.
nO SPACERS NEEDED.
neo_rambo Dec 13, 2005 05:25 PM
your 100% percent sure?
Msedanman Dec 13, 2005 05:31 PM
The 18" fit, and the 19" are bigger, and the offset is only 3mm difference at the rear.
By all accounts, this is a match made in heaven, but to be sure, you'd better test fit or have the seller test fit.
G/L
C.
Sukairain Dec 13, 2005 05:38 PM
Yeah, I'm sure
http://img.photobucket.com/albums/v1...000817copy.jpg
You can probably stuff a 8 piston brake caliper in there and still have room left over.
kidtronix Dec 13, 2005 06:01 PM
Can a chicken fit in a barn?
driftGT350 Dec 13, 2005 06:07 PM
I got them on my 03 G w/ brembos. All I need now are spacers to make it more aggressive, do you think this will be a problem at high speeds or unsafe in anyway?
htownboy Dec 13, 2005 06:19 PM
Amen!
I've seen a couple of coupes setup like this so yes, you can do it.
da mayor Dec 13, 2005 06:23 PM
Originally Posted by Sukairain
great shot
redwillow Dec 13, 2005 06:33 PM
1 Attachment(s)
oh they def fit....and they ride good too
Sukairain Dec 13, 2005 07:09 PM
The front 19" fits the wheel well perfectly, the rear is slightly tucked in and could benefit from a spacer to give it a more aggressive look. I wouldn't want to compromise the safety of the vehicle for looks though. :)
neo_rambo Dec 21, 2005 12:58 AM
Thanks guys
© 2026 MH Sub I, LLC dba Internet Brands
