Question about Gord's grounding gear
Welll, I got GG 10 wire kit, but still have problem with finding Tranny grounding point location.
Do you guys have any pics of tranny strip clamp holding a wire loom? I've read hyper grounding point threads, but pics are all dead. Please post pics or PM me. |
I couldn't get the wire onto the loom either. But I found an unused and threaded hole within 2 inches of the loom and scavaged one of the bolts replaced during the install to mount the tranny wire :)
I consulted with Gordgee when I used this alternate ground spot, he said it should work ok. http://s51.yousendit.com/d.aspx?id=3...23J0HLUFY4SAQJ |
1 Attachment(s)
Is this what you are asking about? :confused:
The wire at the rear left goes down to the tranny. |
When you attach the tranny wire to the place in my picture and drop the wire down to the tranny, the wire length is so perfect that it actually sits next to the only place you can atach it to. That is where I bolted my tranny wire. There should be no confusion as there is only one place you can use. Thanks for perfect length wires Gord!;)
Thanks to Gord, I could finally connect #7 to the tranny G. point.
After seen his pics, everythings got clear to me..:) Thanks guys.
you know I just envy your 13 wire tho.. :D :D :D If I have a chance, I want to see your G sometime...
Thanks for the pics patton! That's exactly what I got from gord. |
After seen his pics, everythings got clear to me..:) Thanks guys. thanks for the pic and nice instruction Cato.. you know I just envy your 13 wire tho.. :D :D :D If I have a chance, I want to see your G sometime... |
PM me next time ;)
My parents live in Austin and I'm there several time a year.
| All times are GMT -4. The time now is 10:14 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
