How can I get More HP with Little $$
Old Apr 30, 2008 | 09:16 AM
jooshee's Avatar
Pretty much what the topic says.
Im new to g35's and cars in general, so I don't know too much.
I don't have much money to spend so how can I get my car decently modded for not too much cash.
Old Apr 30, 2008 | 09:20 AM
Hi-TechG35's Avatar
Depends on what your budget is. For under or around 1500.00 you can get an exhaust, intake, plenum spacer, engine torqe damper and pick up some decent gains. Also check out the marketplace section becasue you can always find awesome deals there be it from a sponsor or a member.
Old Apr 30, 2008 | 09:23 AM
RaginRaj11's Avatar
it depends on how much cash you have. Look into a ztube/pop charger, plenum spacer and a maybe an exhaust.
Old Apr 30, 2008 | 09:25 AM
xjonmo's Avatar
What year is your car? Motordyne 5/16" spacer and MREV2 does the trick if you have a Rev-Up motor (05+ 6MT)
Old Apr 30, 2008 | 11:49 AM
mIKE's Avatar
$$$ and hp go hand in hand.
More $$$ = more HP
Old Apr 30, 2008 | 09:38 PM
Beebo's Avatar
N/a mods: z-tube and MD 5/16 Spacer and a tune
Old May 1, 2008 | 09:14 AM
Redhawk1809's Avatar
Is there a noticeable HP gain when adding the intake, exhaust, and spacer? I'm a soon-to-be proud G35 owner and absolutely can not keep it stock for long.
Old May 1, 2008 | 09:41 AM
Beebo's Avatar
yes... make sure and have the car tuned as well
Old May 1, 2008 | 05:53 PM
Slavik's Avatar
Go for looks, handling and the mods that will give it cool sound … you can’t make a car truly fast on a budget (<$8k)
Old May 1, 2008 | 05:59 PM
Lolly Baggins's Avatar
Nitrous.
Old May 2, 2008 | 12:22 PM
jooshee's Avatar
would nitrous f up my car? Without anyother upgrades
Old May 2, 2008 | 02:46 PM
Keep it under an 100 shot and you should be fine. Check out more on MY350Z.COM, it gets much more technical and it will help you also.
http://www.my350z.com/forum/forumdisplay.php?f=181
Check out the stickies and everything.
Old May 2, 2008 | 06:21 PM
officerdbag's Avatar
XO2 dual exhaust. $500
Old May 2, 2008 | 09:12 PM
Triple8Sol's Avatar
Topspeed 2.5" exhaust, Helix test pipes, Motordyne plenum spacer, JWT popcharger or Stillen intake. All of that together will be just over $1K.
