G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Info on putting OEM forged Coupe 19's on Sedans. (https://g35driver.com/forums/g35-sedan-v35-2003-06/102362-info-putting-oem-forged-coupe-19s-sedans.html)
bmott Jun 6, 2006 02:49 AM
wheel specs:
19x8 + 30 in front with 225/40/19
19x8.5 + 33 in rear with 245/40/19
but what are people running on the sedans. I have read in a bunch of different places that the optimal for the sedan would be...
19x8.5 + 43 front with 245/35/19
19x9.5 + 43 rear with 275/35/19
but i still can't figure out what the optimum setup is for using this on a sedan.
It seems that half the people use them without spacers and keep the 225/40/19 in front and putting 235/40/19's in the back to prevent rubbing.
then i heard that people are using 10mm spacers in front. Does this let you put 225's in front and 255's in the rear. i feel like that would be a good setup for this wheel choice.
Note i am running at stock height, and i don't want my wheels rubbing if i have 3 guys in the back or something.
i know there is a super long thread on this, but its pretty old
https://g35driver.com/forums/g35-sedan-v35-2003-06/61110-19-coupe-wheel-sedan-thoughts.html
https://g35driver.com/forums/g35-sedan-v35-2003-06/64684-19-oem-rims-sedan.html
and i have looked at this
http://g-owners.com/article_read.asp?id=27
any info would be great, of people running on coupe 19's
(>")> G35 Jun 6, 2006 02:16 PM
The only real option is just to bolt them on. I don't know where you heard that from, but adding 10mm spacers are going to push the wheels out farther from the fender.
Chico Jun 6, 2006 02:47 PM
+1. You can get put them right on and the only thing you have to worry about is the rear that will rub unless you roll your fenders a little. Otherwise, just use 235 tires all around and you're good to go.
Jeff92se Jun 6, 2006 02:49 PM
I have them on my unlowered sedan. No rubbing.
MI SO FST Jun 6, 2006 03:19 PM
I have them on my lowered G35 Sedan with no rubbing
Lowered on 350Z stock suspension
http://i10.photobucket.com/albums/a1...t/DSC03915.jpg
MightyG35 Jun 6, 2006 05:39 PM
MI SO FST.. im suprised that you dont rub in the rear.. I have the same set up as you: 350z suspension.. except that I have the 05 revision springs in the rear. Note that I only rub on sharp turns and on dips. I think that im going to go 235/45/19 on my next tire purchase.
MI SO FST Jun 6, 2006 05:44 PM
hmm, I dont know. I know that every car is different but I also have pretty bad negitive camber. When i went to the alignment shop they said that my drivers side was -2.3 and the pass was -1.6. The pass side isnt that bad and i still dont rub. I even have a set of 350Z track wheels with the stock tires on there and they dont rub either. Going up and down my kinda steep driveway I dont dont rub. Exiting the highway one u turn curves at higher speeds arent rubbing either. I guess it really depends on the car.
godmans Jun 6, 2006 05:50 PM
btw, did i say that your car is #Q$^#@^# CLEAN !
SDG35619 Jun 6, 2006 06:31 PM
damn this is the safe flippin set up I want on my sedan.
Jeff92se Jun 6, 2006 07:05 PM
Um if you wanted to be unique or something, I believe you are about 10 cars too late and about 1 year too late. :)
But I didn't care so I did it.
MI SO FST Jun 6, 2006 07:26 PM
Is that the setup that you got from me??? Send me some pics!!!
MightyG35 Jun 6, 2006 08:25 PM
1 Attachment(s)
heres one.
MI SO FST Jun 6, 2006 09:20 PM
heres one.
Looking good. Definitely a clean look with the kit.
MightyG35 Jun 6, 2006 10:01 PM
1 Attachment(s)
heres another. front view
bmott Jun 6, 2006 10:12 PM
i guess the next question is should i just bite the bullet and spend $1200 to buy them even though i only have 5000 miles 2005 Sedan 6MT wheels and tires, or should i wait till my stock tires go bald (way too long)
i showed pics on the forum to my girl, and she thinks im retarded and can't tell the difference between the two. Give me some moral support guys. I should do this right?
btw i have a black/black 2005 6MT
© 2026 MH Sub I, LLC dba Internet Brands
