G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Help, my car won't move!!!!!! (https://g35driver.com/forums/g35-sedan-v35-2003-06/129443-help-my-car-wont-move.html)
JohnVQ35 Dec 9, 2006 03:43 PM
1 Attachment(s)
I'm new to this board. I have an '05 G35x with apprx 18,000 miles on it. I went to start it this morning and it started perfectly but when i went to change gears the shifter wouldn't move from park position. Btw its an auto. I tried to forcefully move it but it is stuck in park. Then as soon as i tried to move it, the lights below in the pic lit up on the dash. I turned the car on and off many times but I can't move from park or drive. What can i do?? I'm stuck.
Neal376 Dec 9, 2006 03:49 PM
try this
turn the car to the on position...see if you could move it into neutral. if you can - do it- than turn the car on while in neutral than shift into Drive. I had that problem with my mustang....but who knows :confused: :confused: :confused:
InTgr8r Dec 9, 2006 03:53 PM
did you search???
here's one example LINKY
..... there's tons of info available.
OneFast4DoorG35 Dec 9, 2006 04:00 PM
try resetting the ecu by unpluging the battery.
Also check and see if the shifter lock is on, if it is then turn it off.
JohnVQ35 Dec 9, 2006 04:27 PM
sorry if i sound naive, but how do i unplug the battery / how do i turn off the shift lock?
Neal376 Dec 9, 2006 04:28 PM
10 mm socket on neg terminal
flat head screwdriver tipped w/ electrical tape on "Shift Lock" next to shifter in cabin
JohnVQ35 Dec 10, 2006 12:41 AM
turning off the shift lock worked but is only a temporary solution. When i go back to park i cant move it again. I tried unplugging the battery. Didnt work either. I unplugged it for about 10 min. Do i need to leave it unplugged overnight? or should i just take it to the dealer?
OneFast4DoorG35 Dec 10, 2006 01:20 AM
leave it unplugged overnight, then take it to the dealer monday.
RetAF Dec 10, 2006 03:26 PM
:D Just to kill time while you are waiting, the owners manual has a great plot!;) :D
sloppymax Dec 10, 2006 04:56 PM
Sounds like a neutral safety switch went bad.
codeflux Dec 10, 2006 05:02 PM
^^^ there was a TSB on that. take the car to the dealer and they'll take care of it free.
sko Dec 10, 2006 06:32 PM
Oh no :confused:
Actually, the exact problem happened to me few years ago, with my 02 altima. I just turned off the shift lock and took it back to the dealer the following day. It was covered by warranty anyway.
sloppymax Dec 10, 2006 09:32 PM
Originally Posted by sko
Oh no :confused:
Same thing happened to 95 altima back in high school. I just started the car in neutral until the dealer replaced the switch under warranty as well.
© 2026 MH Sub I, LLC dba Internet Brands
