She has twins, greddy twins that is...
#466
Going to try some AEM dryflow filters since the Greddy ones suck. They look cool but don't work too well.
If anyone is looking, I got them here:
http://www.speedyperformanceparts.co...number=21203dk
Great deal and free shipping!
Edit: yes i know they are 3" and the greddy pipe is 2.75". The guys over on my350Z tried some 3" K&N ones with good results so I will see how it goes.
#470
#471
#473
If you need a back-up for 2.75" filter, or others with Greddy need one, I have one NIB for $40 shipped. It's a K&N Double Cone filter, Dual Surface = 2 filters in one, for 2.75" pipe, largest surface area possible=Max air flow, Suface area is directly proportional to air flow. Mine is blue, goes well with your Engine bay theme .
I got them for the HKS S/C, but the HKS is too tight, nothing but their mushroom would fit.
#474
I bet!
How far did you drop your engine to do the manifolds and wastegates? Those studs must have been such a pain being under the car!
I feel for you...
But once your tune is done it will all be worth it.
I feel for you...
The manifold were very easy actually.....removing the stock manifolds was far more difficult than installing the greddy manifolds. Installing the turbos onto the manifolds was a different story, though. there is one nut on each turbo that has very limited access.
#476
What is the other measurements on those?
#477
I can't believe it!!! I beat you to a mod!
just swapped mine out for the K&N RX-4960
RX-4960 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 2.75 in (70 mm)
Flange Length: 2 in (51 mm)
Flange Type: Centered
Height: 5.5 in (140 mm)
Top Outside Diameter: 5 in (127 mm)
Top Style: X-Stream
Top Material/Finish: None
Filter Re-Oiling Amount: 0.96 oz (28 ml)
Footnote 1: Filter has molded-in velocity stack
Weight: 1.3 lb (0.6 kg)
Product Box Length: 7.88 in (200 mm)
Product Box Width: 6.94 in (176 mm)
Product Box Height: 7 in (178 mm)
These are 2.75" ID flanges......which is what the greddy piping is.
DRIVER'S SIDE
PASSENGER SIDE
Top Style: X-Stream
DRIVER'S SIDE
PASSENGER SIDE
#479
#480
in your case, I would cut a pass-through hole on either side of the radiator and bring both filters through to the front of the car......similar to how I had my filter when I had my turbonetics kit, only one on each side. I already looked, there is plenty of room on the passenger side to do it. That would look sick!!!
