G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Is it me or it is standard on G's (https://g35driver.com/forums/g35-sedan-v35-2003-06/139822-me-standard-gs.html)
dunglan7 Feb 13, 2007 01:33 PM
I don't know if it's me or not but it seems that my G is going to die out on me. It's very hard to explain. When at stand still, it feels as if it taking big breaths. When I sit in the car it feels as if it's loosing power and then gaining it all within a couple of seconds. When it does feel like it loose power it car kinds of shake. Almost like someone not knowing how to drive a stick shift right. You know when you don't give it enough gas and the car starts to shake. What could it possible be? Or is it just me.
da mayor Feb 13, 2007 01:34 PM
sounds like you might have a fuel injector problem?
dunglan7 Feb 13, 2007 01:39 PM
Would I have to take it to the dealer for that or would I have to change out to new fuel injectors. Would those fuel injector they sell out Pepboy or Autozone work?
da mayor Feb 13, 2007 01:42 PM
brign it to the delaer have them check it out... 4 year /60k miles warranty works out well
dunglan7 Feb 13, 2007 01:48 PM
That does sound good only thing is my car is a 03 and the warranty is out on it already.
Madman723 Feb 13, 2007 02:20 PM
If it's shaking you could have pistons misfiring. That could be caused by a whole bunch of different things. Fouled spark plug, clogged injector, etc. How many miles do you have on it?
ttrank Feb 13, 2007 02:36 PM
Sounds like a misfire to me. As the guys above said, it could be bad or old plugs, clogged injectors, bad gas, dirty air filter, dirty throttle body, etc...
dunglan7 Feb 13, 2007 02:36 PM
I have about 75,000
dunglan7 Feb 13, 2007 02:40 PM
With clogged injector do you have to take it to a specialist to clean it or can you just use stuff they sell at like Autozone.
kailep Feb 13, 2007 04:10 PM
If it is fuel injection problem, would this be under powertrain warranty? The bumper to bumper is 4/60k but powertrain is 6/70k. Am I correct?
ttrank Feb 13, 2007 04:10 PM
The best stuff I have found is BG K44. There is a parts store near me that sells it but you may have to look around a little. What I have found is many shops use it as their "fuel clean" treatment for 2-3x the price.
http://www.bgprod.com/products/fuelair.html
DieselX Feb 13, 2007 06:21 PM
Also sounds like a vacuum leak. Doubt he would get that if he didn't mod though.
Texasscout Feb 13, 2007 06:44 PM
I had the same problem with a ford and it turned out to be the throttle position sensor.
BigSash Feb 13, 2007 07:04 PM
DUDE did you get the fuel hose recall done? If not 10 to 1 that is the culprit.
dunglan7 Feb 14, 2007 11:15 AM
When did they have the fuel hose recal? I'll probably get the dealer to check my car the next time I have my oil changed.
© 2026 MH Sub I, LLC dba Internet Brands
