G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   ~!@Anyone's door hard to close?~!@ (https://g35driver.com/forums/g35-sedan-v35-2003-06/1405-anyones-door-hard-close.html)
mrshabo Jan 29, 2003 12:39 AM
It seems to take some extra umph to close the doors on my g35. on all of the doors actually. anyone else have this? i have 4 cars and this is the hardest. people are like what is up with your door. they have to use quite some effort into closing the door. then when they get into my lexus they use the same amount of energy and it sounds like they broke my door by slamming it so hard. so anyone have the same problem as me?
ryoken Jan 29, 2003 02:02 AM
Re: ~!@Anyone's door hard to close?~!@
I notice it does take a little more effort than I'm used to, but not excessively so, certainly not enough force to qualify as slamming. It also helps, when you close the door, to keep contact with it after it shuts.. so it doesn't have a chance to bounce back open.
Msedanman Jan 29, 2003 06:34 AM
I'm real fussy about my doors all closing nicely without slamming. The first thing I noticed about the G's was that the doors didn't need any adjustment, were nice and tight, and aligned real well.
Have a look at yours for squareness, fit, and if the striker and Nader pin come together cleanly. If all looks good then your difficulty is due to 'airtightness'. [img]/w3timages/icons/frown.gif[/img]
An easy way to check that is the leave the window down slightly just to see how the door closes.
Hope this helps, good luck with your G.[img]/w3timages/icons/smile.gif[/img]
https://g35driver.com/rides/spec/pix...1043461973.jpgGsedanman's Coupe
pestilence Jan 29, 2003 03:54 PM
hmm intresting concept gsedanman..
..::pestilence::..
30all Jan 29, 2003 05:31 PM
I paid special attention to the sound of closing door when I visited the deal. door slamming on sedan sounds very solid and clean even my son was impressed. but the couple on the showroom floor sounds
kind of rattling, I think b/c it has frameless windows and windows were down.
Silver/Graphite/Premium/Sports/Winter and love it
sodhi Jan 31, 2003 12:38 PM
gsedanman hit it right on the nose. I have a G35S and when I brought in for the free 1,500 km oil change I complained that the passenger door needed a lot more force to close the door (in addition to a noise coming from the rear deck). The dealer said this was due to the door being out of alignment. Anyways they corrected it and it seems to close without that much force now. However I noticed the same problem on th drivers door- I am going to get it fix when I get my 6,000 KM oil change.
traian Feb 17, 2003 01:40 AM
I have exactly the same problem you're experiencing. The front doors are BAD: I could not believe it: it takes me or my wife, 2-3 tries before the doors close correctly. It's ridiculous !
Have you fixed yours (the alignment stuff) ? Was that it ?
AARONHL Aug 28, 2011 02:26 AM
Anyone have a g35 striker adjustment how-to? :)
JosansG35 Aug 28, 2011 03:21 AM
My trunk is pretty heavy.
BAUSauto Aug 28, 2011 12:29 PM
^ get new shocks?
You can also check the latches maybe someone decided to clean them :dunno: and theres no lube ._.
JosansG35 Aug 28, 2011 05:35 PM
Originally Posted by CarBodyKits (Post 6083615)
^ get new shocks?
Is that what it is? I thought they were just super heavy haha
BAUSauto Aug 31, 2011 02:44 AM
yep shocks can go bad too the easiest way is to to a meet and find someone with a wing and ask if you can open their trunk.. if its way easier then yours then replacement shocks are due.. You can get OEMs or NRGs both offer replacement trunk shocks.. most aftermarket vendors call them "dampers".
GL GL
- Eric
© 2026 MH Sub I, LLC dba Internet Brands
