5AT can't hold on an incline?
Greetings,
Just had the strangest problem with my 05 5AT. On a slight incline of say 8 degrees, the auto trans can not hold the vehicle. I tried to parallel park and it was like having a stick all over again - without the benefit of a hand brake! Caused me to hit another vehicle. Mentioned it during my 15K service, just to be told it was normal. Did a search, but did not see any one else complaining. Suddenly I am a little concerned about having this car in an area with hills... |
i'll test mine when i get it back tomorrow but i don't remember this being a problem on mild inclines
Mine won't hold on my driveway.
Might have something to do with the torque converter stall speed?
That's about the only downside to having a high performance higher stall torque converter in this car. If rolling is such an issue then why use the foot brake and gas? It's not that hard.
Quote:
i like it when that happens because i can pretend i'm in a manual :p
Quote:
damn.. ur a big guy.. might be some weight holdin it down.. haha JK.. |
Quote:
The typical road standards for maximum grade on collector streets is usually 8% (or about 3.6 degrees), and perhaps 10% (4.5 degrees) on residential streets. |
I have the same problem on the parking garage ramps. Wants to roll down.
why didn't you buy a 6MT? :P
I understand it is a bit of an inconvenience but not using the parking brake in a situation like that is bad on the tranny.
i think tat was the only draw back with the earlier sedans..no hand brake..gay
i have a 5AT and my experience is the opposite i have been on some pretty big inclines and my g usually doesn't roll down that is unless i have momentum, but if i come to a slow stop it usually holds and i can even take my foot off the brake and chill.
Quote:
| All times are GMT -4. The time now is 10:04 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
