G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   What's the best gas for my 2004 G35x (https://g35driver.com/forums/g35-sedan-v35-2003-06/188371-whats-best-gas-my-2004-g35x.html)
Beni B Nov 18, 2007 10:56 AM
Hello everybody,
Should I use premium gas for my G35x? Would regular gas be OK to use as well?
The car has 40k.
04G35NYC Nov 18, 2007 11:18 AM
Yes, use super only. i personally wouldn't use regular.
ratm68 Nov 18, 2007 11:31 AM
go by what the manual suggests. Most use premium while other that don't see the point of spending extra use regular. I prefer to follow to manual and only put in premium. Others have used regular without any problem, i'm sure you can search and find many threads on this.
GEE35FX Nov 18, 2007 11:40 AM
The manual reccomends Premium or 91 octane, that is what most people use.
In a pinch you can put regular in but you will lose a bit of performance.
patman530 Nov 18, 2007 11:43 AM
premium dude, she needs premium!
http://upload.wikimedia.org/wikipedi...e_Simpsons.PNG
ScubaSteve312 Nov 18, 2007 12:09 PM
i only buy premium
express705 Nov 18, 2007 12:16 PM
spend the extra 3 bucks a tank.
GixxerSteve Nov 18, 2007 01:54 PM
If you read your owner's manual, it says "Infiniti recommends the use of unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number. If unleaded premium gasoline is not available, you may use unleaded regular gasoline with an octane rating of at least 87 AKI number (Research octane number 91), but you may notice a decrease in performance."
The G's fuel management system makes adjustments for the type of gas you put in your car. The ingition timing, valve timing, spark energy, and of course fuel curve are all adjusted. The car has the ability to run on 87 octane without knocking or detonating because, for lack of a better term, it "de-tunes" the engine. Obviously, using 87 octane over premium will reduce performance, but it will not harm anything. It's just a matter of preference. I choose to use a midgrade 89 octane.
Beebo Nov 18, 2007 01:54 PM
use premium gas...
06g35meister Nov 18, 2007 01:59 PM
i use regular on road trips (except mountain passes, cause i need the bang) but otherwise i use premium, there is a noticeable change in octanes and performance in the VQ's
miltoda Nov 18, 2007 03:15 PM
i have a 06 sedan and I notice a decrease in performance when even using 89. Doesn't seem to want to rev as high and as fast when not using premion. I think shell v-power is one of the best brands.
AgentAero04 Nov 18, 2007 09:19 PM
PREMIUM!!!
I use Sunoco Ultra 94 octane.BIG,BIG differance in performance and milage from 89.I easily get 26 MPG.I don't drive it like a hearse either!
ashish Nov 18, 2007 09:38 PM
premium only
TheTick Nov 18, 2007 11:32 PM
I can't tell the difference in performance when I use regular.
GeeWillikers Nov 19, 2007 11:04 AM
Rtfm.
© 2026 MH Sub I, LLC dba Internet Brands
