G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Trunk won't open from keyfob or button on the dash, ideas? (https://g35driver.com/forums/g35-sedan-v35-2003-06/194772-trunk-wont-open-keyfob-button-dash-ideas.html)
bigwilly Dec 27, 2007 08:59 PM
Last night I loaded up my car with my camera gear and presents for Christmas party. When I got to my friends place, I tried to grab the stuff from the trunk but no response with the trunk release on the keyfob. I couldn't hear the pop sound of the latch disengaging. The button on the dash didn't work either. I fiddled around with the switch in the glove box, tried the keyfob and button on the dash for a while and nothing. I finally had to get my friend to reach in through the ski pass through and pull the anti kidnapping pull tab to release the trunk. I have booked an service appointment with the dealer, but they won't be able to see me for a few days. Any ideas?
G35Papa Dec 27, 2007 10:52 PM
Fuse?
Dudefish Dec 28, 2007 10:39 AM
I believe this is a pretty common issue. My car does it all the time. Just put the key back in the ignition and turn the ignition on and the switch will work again.
marksg35 Dec 29, 2007 09:59 AM
Happens with mine occasionally,very annoying.
chewy Dec 29, 2007 11:48 AM
You need a new harness. I had it replaced at the dealership. Cost me an arm and an leg. Chances are it is not a fuse. This happened to me a month ago and it is very annoying especially when there is no outside trunk release on these cars.
JAYY-G35 Dec 29, 2007 12:12 PM
you need to go in the glove compartment and switch the button on. and you should be good to go.
WILLIE BEANS Dec 29, 2007 12:13 PM
marksg35 i have a question if you dont mind how do you like your tokico d-specs... ??
you can pm me your reply if youd like to..
thnkx ..
Jason@Riverside Dec 29, 2007 03:33 PM
could be the trunk lock actuator...
JAYY-G35 Dec 29, 2007 04:48 PM
Yeah he said it better lol
gwhiz35 Dec 29, 2007 04:55 PM
First, you don't have to be Stretch Armstrong and use the "accidentally locked in trunk pull handle"--there's a smaller wire with a small black plastic tab very close to the pass thru port whose purpose is to open the trunk if the electrics don't work.
Second, try putting a test light on the trunk lock actuator to see if it's a bad actuator or a wiring problem. If the light lights that's good, just get an actuator and install.
bigwilly Dec 30, 2007 12:26 AM
Thanks guys, the dealer had the car for most of the day today and finally got it fixed. Turns out to be a wiring issue in the trunk. The guy said that the wire split or something.
© 2026 MH Sub I, LLC dba Internet Brands
