G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Sedan V35 2003-06 (https://g35driver.com/forums/g35-sedan-v35-2003-06-15/)
-   -   Rear right door power look doesn't work (https://g35driver.com/forums/g35-sedan-v35-2003-06/195859-rear-right-door-power-look-doesnt-work.html)
sergio3986 Jan 4, 2008 09:10 AM
So my rear right door, the power lock won't work via the button on the driver door or by the remote. So I have to do it manually at the lock each time.
Any ideas what could eb the cause? Remedy?
Joe_Camel Jan 5, 2008 05:16 PM
Will it lock but not unlock, or vice versa, or neither? Could it be the little child safety lock on the inside back (although I doubt that would keep the power lock from functioning). Remove the trim and check all the electrical connections, could be something just came loose.
Jason@Riverside Jan 6, 2008 01:24 AM
Door lock actuator:
I have many of them instock since they are pretty commonly replaced:
Drop me a PM with your shipping zip code / vehicle info and location and I will get you a shipped forum price on monday.
https://img.photobucket.com/albums/v...ckactuator.jpg
sergio3986 Jan 7, 2008 11:44 AM
So I basically got annoyed and just manually locked and unlocked several times...and then ti started working...so maybe it just got stuck...? Regardless it's now working. Maybe it got stuck when somebody tried to open the door as it was being unlocked by the driver causing it to jam
If it acts up again I will for sure shoot you a PM to get that part off you. Thanks
Drewer Jan 11, 2008 05:24 PM
Just recently happened to me (driver's side '03 coupe). The lock became intermittent when using the remote or push button on the door. I ended up replacing the door lock actuator. It was fairly easy to do yourself. I shoulda taken pictures and make a DIY, but I started at 9pm on Sunday night and just wanted to get it done. (Took about an hour.)
-andrew
08G37TX Feb 17, 2008 10:28 PM
Hey Jason,
I tried to send you a PM and there is not an option to send you one. How much for an actuator shipped to 76248?
Thanks!
RRG35 Jun 13, 2008 02:01 AM
Jason how much will it cost me if you installed parts and labor?
© 2026 MH Sub I, LLC dba Internet Brands
