car won't start!!!
Hey guys,
I have taken the motor out for a re-build as it was burning oil... i changed the rings and some other bushings... before putting the engine back to the car, i have used a 12v to start the engine up to test for compression.. and everything sounds fine... all looks good.. but after putting back into the car, it won't start... can somebody give me some hints on where i should start checking?? i have checked there are sparks from the plugs, and there is fuel from the injectors.. so what do you guys think?? |
make sure ALL your grounds are bolted up, see if u have spark, see if u have fuel check ur timing, its kind of hard helping you with this one
dose it turn over? did u hook up ur starter right? im not sure but dose the vq35 have a ignitor unit? just tell use exactly what ur car dose while u turn the key, btw, do u hear ur fuel pump turn on? fuses? |
| All times are GMT -4. The time now is 12:30 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
